1992 dakota wont stay running
Old Oct 28, 2009 | 01:55 PM
steffy52's Avatar
steffy52
Default 1992 dakota wont stay running
hey. my 92 5.2 dakota wont stay running. it will normally start right up and then die. but if i constantly have my foot on the gas it will continue to run, but will still feel like it is cutting out and then kick back on. any body else have this problem?
Old Oct 28, 2009 | 02:35 PM
skyshark186's Avatar
skyshark186
Possibly the idle air control valve. Could also be the TPS or MAP sensors. Will it drive ok if you can keep it running? IE. Does the motor run ok at middle/top end and only die/sputter at idle/near idle. When was the last tune up(plugs and wires) and has it had the fuel filter replaced?
Old Oct 28, 2009 | 02:53 PM
steffy52's Avatar
steffy52
i replaced the iacv already. if i drive and hold the gas down you can occasionally feel the truck sputter and kick back on.
Old Oct 28, 2009 | 03:00 PM
95_318SLT's Avatar
95_318SLT
Did you reset the computer after putting in the IAC? There's also the possibility that the new IAC is bad... happens a lot. Have you checked for vacuum leaks? Have you checked the fuel pressure at the rails?
Old Oct 28, 2009 | 03:20 PM
steffy52's Avatar
steffy52
i did not reset the computer. im trying that now. the fuel pressure at the rails is fine, and i havent looked for vacuum leaks which i will do
Old Oct 28, 2009 | 04:25 PM
steffy52's Avatar
steffy52
i reset the computer and still no luck. the truck wont even start now, any other ideas?
Old Oct 28, 2009 | 04:48 PM
skyshark186
You said that the fuel pressure was ok. Whats ok?
If your sure it has fuel, im sure it has air, then that leaves spark. You could try the infamous splice under the pdc. Other ideas might be the coil or ignition module.
Old Oct 29, 2009 | 03:42 PM
tndakman's Avatar
tndakman
I had that exact same problem once upon a time-easy fix-once I'd been towed 5-6 miles to driveway. Broken coil wire(internally)couldn't see externally where it was broken. Hope yours is as easy to fix. I'm talking coil to distributor cap that is-not internal coil windings.
Old Oct 30, 2009 | 03:25 PM
jnracing's Avatar
jnracing
check for a loose ground wire haha did that one once would stay running and cut out every other bump or so lol
