black hose? transfercase?
Old Nov 29, 2009 | 09:23 PM
4x4Dakota93's Avatar
4x4Dakota93
Default black hose? transfercase?
ok im putting the transfercase back on my truck and theres this black hose that hooks up to a nipple on it and i cant seem to find where the other end leads to...
anybody got any ideas? looks like it leads forward
Old Nov 29, 2009 | 09:27 PM
95_318SLT's Avatar
95_318SLT
Probably the breather tube. If thats what it is, it just goes up to any high point on the truck... from the factory I think it goes up into the engine bay near or on the firewall.
skyshark186's Avatar
skyshark186
If by a nipple you mean a small output hose thats got a 90 degree bend it could either be a vaccum line to connect the front axle, or it could be a vent hose.
Old Nov 29, 2009 | 10:02 PM
4x4Dakota93
well the other end of the hose not the end connected to transfercase, has a somewhat 90 degree metal tube clamps on it, and has a a hole spot to be bolted somewhere
Old Nov 29, 2009 | 10:06 PM
95_318SLT's Avatar
95_318SLT
Yeah, thats a breather tube or vent tube (6 on one hand, half a dozen on the other). It follows the wiring harnesses and fuel lines up to the firewall/transmission bellhousing area of the truck and bolts to whatever you want to bolt it to up there. All it does is let the transfer case breath as it heats up and cools down while making sure water or mud doesn't get in it if you like to drive through deep puddles.
Old Dec 1, 2009 | 02:20 AM
dodgerules86's Avatar
dodgerules86
...which reminds me, I need to reinstall mine! Thanks guys for reminding me of these things!
Old Dec 1, 2009 | 02:27 AM
95_318SLT's Avatar
95_318SLT
Lol, if you're like me you'll forget by February!! I didn't have that hose on mine for the longest time, then I just happened to come across it when I was putting in the 242 and remembered, so now it's finally back in place.
Old Dec 1, 2009 | 02:48 AM
dodgerules86
Yea. Once I actually get the thing road worthy (just gotta remove and properly install a torsion bar and fix the squishy brakes/always on brake lights), I'll look thru it and fix those little things.
I also need to replace the switch on the transfer case that illuminates the "4x4" light.
