oops.
Old Feb 13, 2010 | 06:09 PM
  #21
Az93DKota's Avatar
Az93DKota
Originally Posted by LO 619
good to know. I'm going to change the oil again anyway and I'm going with amzoil so 4 quarts is almost 9 bucks cheaper.
Also, I've heard about going up to thicker weight oils based on mileage due to engine wear, a guy told me I should use 10-40 rather than 10-30. Have you heard of this?
I use 10w40 in the summer and 10w30 in the winter. And since you're from SoCal you know about all the stop and go BS. I've always used regular oil. And I did add a trans cooler for the high heat summers we have.
I don't really see a reason to use a thicker oil cause it has high mileage. Either way with w30 or w40. You'll still get an oil bearing.
