whats next on the repair list for a bad idle?
Old Apr 18, 2010 | 12:36 AM
  #61
shadowthedakota's Avatar
shadowthedakota
oh and after about an hour and 30 miles of part chasing i bought a new engine coolant temp sensor to replace the one that broke behind the ac compressor.
Old Apr 18, 2010 | 12:29 PM
  #62
shadowthedakota
i put the new sensor in today and ran the engine and it seemed to miss when revved up... maybe its just cold (i hope thats it).
Old Apr 18, 2010 | 12:40 PM
  #63
95_318SLT's Avatar
95_318SLT
Is it idling better at all?
You should reset the computer and drive it down the highway for 20 minutes to give the computer a chance to learn! My truck always runs better if I do that after making a major modification.
Old Apr 18, 2010 | 08:13 PM
  #64
shadowthedakota
it has a backfire when it starts up idle is ok, but it tried to taker it to a gas station by my house cuz its getting low on gas. i got about a tenth of a mile down the road and she started backfiring like crazy. but it was only up in the higher rpms(anything above 2k) that it did it. i would have taken it down the freeway but i have to bend my shifter again so i'm not hitting my dash when i put it in first, third or fifth(it goes in those gears but i almost have to smash the shifter into the dash to get it)
Old Apr 18, 2010 | 10:41 PM
  #65
Crazy4x4RT's Avatar
Crazy4x4RT
For the backfiring you may need to adjust the distributer if off. Or check your plug wires for the correct order on the distributer.
Old Apr 18, 2010 | 10:52 PM
  #66
shadowthedakota
if i finally am able to get up around 6 am i'll double and triple check everything. now if only i had a timing light. the only problem with that is the closest timing light i have available is about and 1hr 30min away and i don't want to spend 40$ on a new one...
but i definitely wont be around this weekend to do any work on it, i'm going to the Jefferson car show and swap meet in jefferson cty,WI. from what i hear its pretty big.
Old Apr 19, 2010 | 07:58 AM
  #67
tmacdakota's Avatar
tmacdakota
You can check the timing with a light, but I believe all daks after 92 have fixed timing...non-adjustable.
Old Apr 19, 2010 | 01:57 PM
  #68
Crazy4x4RT's Avatar
Crazy4x4RT
Yes it is computer controlled non-adjustable. But the distributer is adjustable. If not in the correct location the computer can't adjust it beyond a point.
Old Apr 19, 2010 | 04:05 PM
  #69
95_318SLT's Avatar
95_318SLT
Actually, tmacdakota is right. Straight out of the FSM...
Base ignition timing and all timing advance is controlled
by the powertrain control module (PCM). Because
ignition timing is controlled by the PCM,
base ignition timing is not adjustable on any of these
engines.
Old Apr 19, 2010 | 05:33 PM
  #70
Crazy4x4RT's Avatar
Crazy4x4RT
engines.
Yes Timing is not adjustable, I'm not talking about the timing. But the distributer is adjustable.
It must be lined up correctly. See pic Straight out of the FSM. The computer can't adjust the timing enough to compensate for a miss-adjusted distributer, which can cause misfire, backfiring, pre-detestation.
(4) Position distributor into engine to its original
position. Engage tongue of distributor shaft with slot
in distributor oil pump drive gear. Position rotor to
the number one spark plug cable position.
Even then it is not correctly positioned. To get it perfect and to have the Fuel Sync set you have to use a scanner.
