Power Loss Issues
Old 05-05-2010 | 09:40 PM
doctormod's Avatar
doctormod
ok, soooo...I have done the tune up including all the plugs and wires and what not. the cap and rotor were in *bad* shape. also i changed the pcv valve and the iac valve. i also cleaned the oil off of the back of the engine and the bell housing. the truck runs a LOT smoother now and power delivery is much more fluent for the most part. the other part...there is still a particular window of revs (about 1100rpm-1600rpm) the engine stumbles and sputters a bit. i am not sure what could be causing it at this point because at this point i have narrowed the issue down to the engine i think. any ideas?
Old 05-05-2010 | 09:48 PM
95_318SLT's Avatar
95_318SLT
Did you gap all your plugs to .035"?
Old 05-05-2010 | 11:27 PM
doctormod's Avatar
doctormod
I did good sir. I found the info on a forum and was hoping it was correct.
Old 05-06-2010 | 01:39 AM
Auron's Avatar
Auron
Originally Posted by 95_318SLT
Lol, I can't remember the last time I shifted my truck at that low an RPM! I usually ride it out through 4000+. I'll ride it through 5500 if someone desides to get smart with me at a red light :P
you too must be a manual thing, but mine peaks around 5200 the only time i do that is to annoy the guy next to me or scare kids following me on bikes
Quick Reply: Power Loss Issues
