Clockspring
Old May 30, 2010 | 01:25 PM
maxpowerpokemon's Avatar
maxpowerpokemon
Default Clockspring
If you have replaced yours, where on earth did you buy it? None of the auto places around us have one and only one of them can even order it for us.
I don't want to go to the dealership if I don't have to because they want an arm and a leg for it.
Also...how much should a new one cost? I'm being told over $210...and that just seems high.
Old May 30, 2010 | 03:09 PM
Crazy4x4RT's Avatar
Crazy4x4RT
I'm not sure which places you tired. But you can check most online. Very easy.
http://www.rockauto.com/
www.autozone.com
www.napaonline.com
http://www.oreillyauto.com
Try OEM sites.
https://www.dodgeparts.com/oe_parts_...e2cf8fa4e8846c
http://www.moparpartsamerica.com/par...?siteid=214583
If you can't find it try by part number. The part manuals are in the FAQ in this section.
Try your local junkyard. Or www.ebay.com or www.craigslist.org
Old May 30, 2010 | 04:37 PM
maxpowerpokemon
www.autozone.com
www.napaonline.com
Try OEM sites.
I've called our local Autozone, Advance Auto, Napa, and two other auto parts places and NONE of them carry a clockspring. Also told me that they will not order it, I have to go through a dealership.
I've looked online and the best price I can find is at moparpartz.com and that's $174.
I'm just trying to make sure I'm not being taken for a ride.
THANKS!
Tim
Old May 30, 2010 | 06:32 PM
Az93DKota's Avatar
Az93DKota
What year truck do you own?
Most ZJ Grand Cherokee's share parts with our gen Dakota's. I always check junkyards for 1st gen Dakota and Jeep ZJ models for parts.
Old May 30, 2010 | 07:39 PM
maxpowerpokemon
it's a 96
Old May 30, 2010 | 07:54 PM
Az93DKota's Avatar
Az93DKota
Originally Posted by maxpowerpokemon
it's a 96
You should be able to find one from a GC
Old May 31, 2010 | 05:37 PM
dodgerules86's Avatar
dodgerules86
I should replace mine, but I'm not going to.
I know mine is bad because the horn would come on sometimes when turning the wheel, and a few days later, the airbag light came on, and than a few days later, pieces of copper wiring popped out by the steering wheel. I immediately disconnected the airbag.
But, since all the clock spring is for is- airbag, horn, and cruise control; all things I don't need (except the horn, will mod the wiring for the horn later), I have no plans on replacing it.
Old Jun 1, 2010 | 01:12 AM
Auron's Avatar
Auron
what exactly is a clock spring
Old Jun 1, 2010 | 01:37 AM
Crazy4x4RT's Avatar
Crazy4x4RT
It is behind the steering wheel. It is a cord that winds and unwinds as you turn the wheel. It holds the wires for Horn, Cruise control, Airbag, Remote radio ect on newer models. It is call a clock spring because of the way it looks. Like a wrapped around clock spring.
Old Jun 1, 2010 | 02:16 AM
Auron's Avatar
Auron
ohhh ok i get it now
