1993 Dodge Dakota water leak
Old 10-26-2010, 01:30 AM
boberety69's Avatar
boberety69
boberety69 is offline
Default 1993 Dodge Dakota water leak
I have a 1993 Dodge Dakota LE which leaks water into the drivers side floor. I've heard this is pretty common, but I do not know where it is leaking from. Has anyone had and fixed this problem? Any help would be appreciated.
Old 10-26-2010, 02:37 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Crazy4x4RT is offline
When does the it leak? When it rains? When you have on the AC? Just out of no where?
Old 10-26-2010, 02:40 AM
boberety69's Avatar
boberety69
It leaks when it rains.
Old 10-26-2010, 03:03 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Probably from the cowl. Take off the panel and check the corners ect.
Old 11-07-2010, 06:16 PM
memasterac's Avatar
memasterac
memasterac is offline
What panel to take off? and what corners to check? can you please be more specific? Thanks.
Old 11-07-2010, 06:50 PM
Crazy4x4RT's Avatar
Crazy4x4RT
The cowl is the panel where the wipers arms come out of. Check the corners around the leak spot.
Old 10-20-2011, 11:53 AM
64zz430's Avatar
64zz430
64zz430 is offline
i had a water leak on the passenger side took of the plastic cowl under the wiper blades and took some black RTV sealer put it on my finger more than once and spead it in the corner seam all the way to the front and also put some around the intake vent and the water leak stopped. you will have to lay on top of the motor to get at it.
Old 10-20-2011, 11:57 AM
64zz430's Avatar
64zz430
64zz430 is offline
sorry buy the way my leak is on a 04 dakota
Quick Reply: 1993 Dodge Dakota water leak
