Turn Signal Flasher
Old Jan 24, 2011 | 10:54 PM
schrock_86's Avatar
schrock_86
Default Turn Signal Flasher
I spliced a 4 pin(flat) trailer connector into the stock taillights. The lights flash very fast when hooked up to a trailer. I'm assuming this is due to the extra load of the trailer. Could I solve this by using a flasher with a higher load rating?
Old Jan 25, 2011 | 01:19 AM
Crazy4x4RT's Avatar
Crazy4x4RT
When does it flash fast? At all times? Only when the brakes are on? Only when both or only 1 side turns are on?
It sounds like something is not hooked up correct. The brake has to be off of the switch and not the tail lights.
Old Jan 30, 2011 | 12:06 AM
schrock_86's Avatar
schrock_86
Both sides do it. It doesnt matter if the brake is depressed or not.
Old Jan 30, 2011 | 06:55 AM
festerw's Avatar
festerw
It's a ground issue most likely, check that you have a dedicated ground wire to each light on the trailer from the trailer plug. and also that the ground on the truck side is clean and tight.
Old Jan 30, 2011 | 10:11 AM
22DODGE22's Avatar
22DODGE22
The answer is you need a heavy duty flasher!!!. Just stop at any auto parts store and get one. This is a normal thing to occur with a standard duty flasher.
Old Jan 30, 2011 | 02:09 PM
bowhunter2k9's Avatar
bowhunter2k9
I got the same problem, except only one of mine does that. every time i turn the blinker on it goes very fast and very dim... and if you keep doing it it will blow the fuse
Old Jan 30, 2011 | 08:18 PM
22DODGE22's Avatar
22DODGE22
Your problem is totally different than the OP. Your problem is that you have a short somewhere!!!
Old Jan 31, 2011 | 04:07 PM
schrock_86's Avatar
schrock_86
Thats exactly what I had assumed. I'll have to pick one up and see what happens.
