95 dakota 5.2 firing troubles please helpp!!
Old Feb 18, 2011 | 05:18 PM
felicia's Avatar
felicia
Default 95 dakota 5.2 firing troubles please helpp!!
hello, is there anyone here who can help me. i have a 95 dodge dakota, that will not fire. i have tried a new coil, a pick up coil in the distributer, and a computer , none has fixed my problem. do you know what it could be?
Old Feb 18, 2011 | 11:44 PM
dwm260's Avatar
dwm260
Wrong place. I'm sure if you post it in the threads not in the general discussion people will help you. This is a non-tech related section. :O
Old Feb 19, 2011 | 10:26 AM
siggie30's Avatar
siggie30
If your not getting spark, then replace the crank position sensor. This is typical of higher mileage engines and next in line of replacement "things". Have you checked your fuel pressure?
Old Feb 19, 2011 | 11:13 AM
jnjinfla's Avatar
jnjinfla
Also make sure your fuel sync is on. If it is off the signals will not read one another and shut the coil down. Been there done that and the diagnosis was a PITA.
Old Feb 19, 2011 | 11:53 AM
pashadowops's Avatar
pashadowops
Did you already check the splice under the power distribution center in the engine compartment?
When you turn the key to the on position, do you hear the fuel pump priming the lines?
Are you getting any spark at all, or does it just turn over?
If you are getting no spark and cannot hear the fuel pump, most likely it is the splice.
Old Feb 19, 2011 | 02:36 PM
felicia's Avatar
felicia
we have checked the splice thats not it, were leaning towards the crank sensor but dont want to purchase one until we know for sure is there a way i can test this?
Old Feb 20, 2011 | 01:54 PM
siggie30's Avatar
siggie30
Pull the sensor and check for resistance.
Old Feb 20, 2011 | 02:54 PM
felicia's Avatar
felicia
thanks, for all your help! it seems the crank sensor was the problemm!
