Changing transfer case fluid.
Old Aug 20, 2011 | 05:51 PM
huseman808's Avatar
huseman808
Default Changing transfer case fluid.
Does anyone have a writeup on this? My 4x4 lever is really hard to move, and ive been told that fresh transfer case fluid could help with that.
How do you drain, and add fluid?
What kind of fluid?
And how much fluid?
Thanks.
Old Aug 20, 2011 | 06:03 PM
huseman808's Avatar
huseman808
By the way its a 96 Dakota 3.9L. I dont have my ram anymore and im to lazy to fix my sig lol
Old Aug 20, 2011 | 07:18 PM
Hahns5.2's Avatar
Hahns5.2
Changing the fluid wont make it shift better. Have you looked under your truck? It's 2 big plugs, lower one is drain, top one is fill. ATF +4. 2 quarts is more than enough.
Old Aug 21, 2011 | 10:41 AM
g. man's Avatar
g. man
1. Why wouldn't it shift better with new fluid? Every time I've ever replaced my transmission fluid there is a big difference in shifting. I use $13 a quart red-line though. I would think new transfer case fluid can only help the situation.
2. NP-205 uses SAE SF 10-30 Engine oil.
NP231, and NP241HD use DExron III ATF.
Old Aug 24, 2011 | 08:49 PM
huseman808's Avatar
huseman808
Cool, ill give it a shot. How do I know which transfer case I have? I got the 3.9L, 1996 model year.
Thanks
Old Aug 25, 2011 | 02:27 AM
Crazy4x4RT's Avatar
Crazy4x4RT
NV231 all 1st gen except 87 came with it.
Old Aug 25, 2011 | 12:30 PM
Hahns5.2's Avatar
Hahns5.2
Because a transfercase is competely different from a transmission
And it's ATF+4, not Dexron.
Old Aug 25, 2011 | 01:58 PM
qlty94's Avatar
qlty94
15 1/2 years old go under and check linkage & bushings & lube them
Old Aug 25, 2011 | 03:30 PM
g. man's Avatar
g. man
Obviously, but old, dirty fluid with metal pieces in it is not good for anything. Changing his old fluid can only help the situation.
My service manual states the NP231 takes Dexron III, but it's been wrong before.
