Moper Performance Computer.
Old 09-21-2011, 09:54 PM
91Dakota318's Avatar
91Dakota318
91Dakota318 is offline
Default Moper Performance Computer.
I am looking at getting a performance computer for my 93 Dakota V8. And I am wondering what other upgrades i should do. Its bone stock. LEt me know.
Old 09-21-2011, 11:45 PM
Hahns5.2's Avatar
Hahns5.2
Hahns5.2 is offline
Do it. Supposedly a 94-95 computer will work, at least the guy I got mine from said it worked fine in his 93. Also Ram 5.9 computers work (what mine is).
Another great mod is Harland Sharp 1.7 roller rockers, the non-adjustable ones bolt right on and are good for about 10whp and make the engine a lot smoother in the upper RPMs. Mopar M1 intake manifold. Exhaust of your choice. 50-52mm throttle body. The list goes on.
Old 09-22-2011, 10:38 PM
RockGuardedDak's Avatar
RockGuardedDak
RockGuardedDak is offline
Did you notice a difference in anything by running a Ram 5.9 computer? I have access to one, and if it would be beneficial, I would change it, short of that, I'm gunna by a Mopar Performance computer soon enough
Old 09-23-2011, 01:02 AM
Hahns5.2's Avatar
Hahns5.2
Hahns5.2 is offline
I meant 5.9 Mopar PCMs, not the stock 5.9 PCM.
Old 09-23-2011, 05:18 PM
RockGuardedDak
oh ok, well is there really any difference in the two in terms of performance?
Old 09-24-2011, 02:06 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Crazy4x4RT is offline
Yes the Mopar Performance PCM is better, yes it does give more performance vs stock. But on a stock truck you will see a little improvement when swapping it on. It wakes up the more performance parts you put on.
I got the 94-95 5.9 Mopar Performance to go with my 5.9 Magnum on my 93 Dakota.
Old 09-25-2011, 11:49 AM
RockGuardedDak
I know, I mean in terms of the 5.2 performance PCM vs. the 5.9 performance PCM
Old 09-25-2011, 03:03 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Yes, 2 different motors with different values so the 5.9 needs to be different from the 5.2 due to size ect.
I'm assuming (since none of your questions are in full depth that is why no one is answering your questions correctly because we don't know what your asking) that your asking if you can put a 5.9 Mopar Per. pcm and it would have more power than the Mopar Per. 5.2 pcm onto a 5.2 engine.
Yes it would have more power. But it is possible it would run to rich poor MPG and if you have state or city emissions or inspections it may not pass.
Old 09-25-2011, 05:53 PM
RockGuardedDak
I guess I just assumed some people would be able to put 2 and 2 together from the topic at hand between me and Hahns5.2 . Sorry for assuming
Old 09-25-2011, 07:37 PM
Hahns5.2's Avatar
Hahns5.2
Hahns5.2 is offline
Having never ran a 5.2 Mopar PCM I can't say if the 5.9 Mopar PCM makes more power than it, 95_318SLT claims the 5.9 Mopar PCM had better performance over the 5.2 Mopar PCM on his 5.2.
Having run a wideband with the Mopar PCM, the AFRs are just fine, not too rich at all.
Quick Reply: Moper Performance Computer.
