new water pump leak
Old Nov 1, 2011 | 07:08 PM
gatorchin's Avatar
gatorchin
Default new water pump leak
just installed new water pump...started up truck after letting it sit overnight and it leaks like crazy..seems one of the long bolts (top right) is leaking, and it seems like it was also leaking near the bottom somewhere...i used red rtv sealant...is this coolant compatible??..also i did not use any sealant on the threads of long bolts..could this also cause a leak??..can anyone offer some advice??..im gonna tear it all down tomorrow and install new gasket and try this again so i would like to go into this with a little more confidence than i have right now...grrrr
Old Nov 2, 2011 | 01:52 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Did you ONLY use RTV or did you use new gaskets and a THIN layer of RTV? Did you clean off the old gaskets good?
Old Nov 2, 2011 | 06:34 AM
gatorchin's Avatar
gatorchin
i used the gasket and red rtv...on the engine mounting surface side and on the water pump side....too much???
Old Nov 2, 2011 | 06:35 AM
gatorchin's Avatar
gatorchin
oh and i used a wire wheel to clean off the old gasket
Old Nov 2, 2011 | 08:38 AM
marcar1993's Avatar
marcar1993
Make sure its coming from the mounting surface first, if so, take it back apart, clean it with a razor blade scraping ALL the old material off till you have shiny silver surfaces. Then a thin "tack" coat of permatex ultra seal on both sides of the gasket, then re install and make the bolts tight. Never had a problem doing it that way. And if the bolts are tight, they shouldn't leak.
Old Nov 2, 2011 | 11:20 AM
crazyjerry's Avatar
crazyjerry
book says 30ftlbs on them bolts.
Old Nov 2, 2011 | 11:27 AM
gatorchin's Avatar
gatorchin
i'm thinking where it was leaking out of the bottom it may have been coming out of the weep hole..i have to crawl under it to make sure..if so i'm gonna take the pump back to autozone and get a replacement...i'll also use your suggestions and get some different gasket sealant and make sure i get the surfaces 100% prepped before re installing..thanks guys
Old Nov 2, 2011 | 03:24 PM
misfitdakota_95's Avatar
misfitdakota_95
you might also want to check your bypass hose. It's behind the A/C compressor bracket. To replace it, you'll have to remove the A/C compressor, & the alternator to remove the bracket.
When I replaced my water pump on my Jeep Grand Cherokee 5.2 V8, I had a leak coming from the heater hose tube. I ended up replacing the o-ring, because it was the wrong one from NAPA, sealed it up with black RTV and have had no leaks now for the past 5 months.
Old Nov 2, 2011 | 07:58 PM
gatorchin's Avatar
gatorchin
i removed the a/c, alternator, and the bracket that both of those mount too..there was some moisture around the thermostat housing, also a big pool where the bypass hose hooks in..i don't know if it was leaking down from the thermostat, or a little of both...so i bought a new thermostat gasket, new bypass hose, and while i was at it returned the water pump and got a new pump and pump gasket...i also got the permatex made especially for thermostats and water pumps...so i got all the surfaces prepped to shiny metal and ready for install tomorrow..i also noticed the heater tube didn't seemed to be sealing up real well so i'll throw some permatex on that too..i'll let you all know how it goes and again thanks for the help
Old Nov 2, 2011 | 10:42 PM
kahanabob's Avatar
kahanabob
if the heater hose is long enough (should be) cut 1" off the end (just above the clamp marks} then clamp it down. don't put the thermostat in upside down...
