Rear Shackle Hanger Replacements
I recently picked up a 95 Dakota 4x4 and the rear spring hangers are all rusted out and the one on the passengers side is just destroyed. I was thinking about making new ones because I can't seem to find them. I searched on here for an hour or so and didn't really come up with anything and I did find one kit online, but at $269 I will build my own.
But does anyone know who sells stock replacement shackle hangers???
Thanks in advance
Thanks in advance
I'm assuming this is the same kit you found since it is the same price.
http://www.autoandtrucksprings.com/p...-1885-158.html
But if you just want the brackets alone they are $92.
http://www.autoandtrucksprings.com/p...r-1886-81.html
The rivets will need to be cut off and then punched out, then drill out the holes with a 1/2in drill bit to get some 1/2 grade 8 bolts in. I swapped in some brackets to lift up the rear end.
Ranger leafs are 2.5" and I' pretty sure that I can make the work. Especially considering I'll save almost $200.
I'll see what happens this weekend, but I also have to patch up a hole in the box where the leaf spring was hitting, finish the exhaust, install the rear shocks, and clean it up really good as well as checking all of the fluids.
