What is Shock Stroke?
Old Jan 30, 2012 | 01:46 PM
InnerCityHillBilly's Avatar
InnerCityHillBilly
Default What is Shock Stroke?
What is shock stroke? need to buy new front shocks and saw shock stroke followed by a number? what would be the best stroke
Old Jan 30, 2012 | 04:11 PM
Crazy4x4RT's Avatar
Crazy4x4RT
I can't remember if you have just stock or if it is lifted. But stock shocks will even handle a lift with the indexed keys 2-3in.
If you really want to know the stroke of the shock, remove your shock and measure. www.napaonline.com also lists lots of dimensions.
Old Jan 30, 2012 | 11:50 PM
InnerCityHillBilly
my truck is stock height. Quick question about the torsion bar though. I had my truck in class (i go to school for automotive) and was lookin over my truck with one of the teachers and he said that the spring was fully tightened, but it is sagging and i have never touched them before, but what i wanted to ask is, is do i have to worry about the torsion bar breaking on me if i try and tighten the bar up and level the sagging side? and from what i have compared to other stock 1st gen 4X4's my truck would be at stock height.
Old Jan 31, 2012 | 01:43 AM
Crazy4x4RT's Avatar
Crazy4x4RT
No you will not brake it, as long as it is in good shape no rust or major dents or scraps. I thought the same thing before I cranked mine up. The torsion bars handled heavy abuse from me. The front axle broke way before the bars could. No major air jumps though.
Old Jan 31, 2012 | 12:42 PM
InnerCityHillBilly
is the best way to crank it to use a breaker bar and a cheater pipe? or is there a better way
Old Jan 31, 2012 | 03:56 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Ya just a breaker bar. If you lift the front end up you will release some tension to make it easier to turn the bolt. Make sure you take measurements on both sides before and after, get both sides equal.
Old Feb 1, 2012 | 11:26 PM
InnerCityHillBilly
another question. If the torsion bar is fully turned out would the best way to fix it be buying after market keys and what dodge vehicles are the torsion bars able to swap into a 1993 dakota?
Old Feb 2, 2012 | 01:55 AM
Crazy4x4RT's Avatar
Crazy4x4RT
I'm sure your not Max out on the stock torsion bar key, if you are someone already cranked it up to get more lift. The Indexed keys will have crack it up more. There is no interchange with the torsion bars.
