Sounds like a coffee can?
Old Jan 30, 2012 | 09:11 PM
high_on_lif's Avatar
high_on_lif
Exclamation Sounds like a coffee can?
Anybody know why my 3.9 sounds like its running inside a coffee can when I'm accelerating? I've changed all the standard things and finally got it running smooth, but it still sounds funny to me. Is it in the exhaust system or what?
Old Jan 30, 2012 | 09:34 PM
melodytoinvent's Avatar
melodytoinvent
Lol I'd imagine you'd be able to pinpoint a sound like that. What all have you changed? Usually a sound like that, during acceleration, I'd say yeah, its probably the muffler/exhaust broke, blown out, vibrating, or just shot so yeah, its loud.
Old Jan 30, 2012 | 11:18 PM
high_on_lif
Just got the truck a couple months ago. Changed all the filters (oil,air,fuel), both temp sensor and temp sending unit (which finally fixed the idle loping problem.), throttle position sensor, thermostat, and a few bulbs. It's not loud. just has that metallic "ring" to it. Don't know how else to explain it. I'm no mechanic by any means, but I'm not afraid to get my hands dirty to save a couple hundred bucks.
Old Jan 31, 2012 | 01:45 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Sounds like a rattle or a shake or a pinging sound. Maybe some thing is loose or you got an exhaust leak or it is pinging which is due to pre-detonation which can be a common problem.
Old Jan 31, 2012 | 11:02 AM
AZ 360 Dakota's Avatar
AZ 360 Dakota
Try running a higher octane fuel. If you're running 87 go up to 91. If it goes away then it's preignition/detonation. What year is your truck? What is your fuel pressure at?
A.J.
Old Jan 31, 2012 | 12:34 PM
high_on_lif
A.J.
I'll try that. It's a '93. I haven't checked the fuel pressure. I might get a chance to do that this weekend.
Old Jan 31, 2012 | 07:13 PM
crazyjerry's Avatar
crazyjerry
metallic ring sound can also be the stuff inside the catyletic converter rattling. mine does it but its nothing to be concearned with. if you live in a state that does emissions then you may have a problem when the put the tester in the tailpipe. for non emission states its no big deal
Old Jan 31, 2012 | 08:47 PM
melodytoinvent
I see what ya mean and didn't think of pinging. I would check your exhaust and see if its loose ANYWHERE or if the muffler or cat rattle when you hit them but also still check your fuel pressure and try a higher octane like suggested just in case.
