What gives better performance?
Old Feb 6, 2012 | 12:27 AM
Siwon's Avatar
Siwon
Default What gives better performance?
1995 Dodge Dakota SLT 3.9L V6 automatic 2wd
What can I replace or add to get better throttle response and performance?
Let's say some parts haven't been replaced in the past few years, what usually causes slight or drastic performance issues?
Old Feb 6, 2012 | 02:21 AM
WRXCarl's Avatar
WRXCarl
Gain 2 more cylinders ... Personally I'm about to change the o2 sensor, MAP sensor, remove and clean the throttle body (also replacing the $4 gasket on that obviously) and replace the air filter with a K&N these alone should help performance and MPG's but I highly suggest you read the FAQ it has all the tune up ideas https://dodgeforum.com/forum/1st-gen...e-manuals.html
Old Feb 6, 2012 | 02:38 AM
Siwon's Avatar
Siwon
In the FAQ it says the Autolite 3923 was the best performance.
Has anyone tried the E3 DiamondFIRE spark plugs?
http://www.autotrucktoys.com/dodge_d...-PRD13908.aspx
The reviews made me want to try them.
Old Feb 6, 2012 | 02:47 AM
MoparMan1991's Avatar
MoparMan1991
Get an intake made up and get a better flowing muffler, that should help some. As far as acceleration you could always upgrade to higher gears. Affordable if 2wd expensive as f*ck if you have a 4wd.
Old Feb 6, 2012 | 03:00 AM
Siwon's Avatar
Siwon
What muffler and intake would you recommend? I bought my last intake for a car from ebay and the only one at autozone is $149.99.
Old Feb 6, 2012 | 07:55 AM
festerw's Avatar
festerw
Stick with the cheap copper plugs, they perform better in these engines.
Old Feb 6, 2012 | 09:57 AM
g. man's Avatar
g. man
I hated my 3.9 till I put in a performance chip. Power, and gas mileage increased considerably.
Old Feb 6, 2012 | 01:06 PM
Siwon's Avatar
Siwon
I was looking at performance chips Here yesterday. Is this what you have?
Old Feb 6, 2012 | 01:38 PM
Crazy4x4RT's Avatar
Crazy4x4RT
That is junk. Jet Chips is the only kind that works, for some reason they are only good for V6 not V8. http://www.jetchip.com/Shop/shopdisp...ppp=10&catID=1
Old Feb 6, 2012 | 02:10 PM
MoparMan1991
Just make your own intake out of whatever your intake size is out of PVC and paint it. It works just as good as the expensive kits do for a fraction of the cost. Muffler wise thats up to you. Do you want quiet or loud?
