A500 hydraulic lockup vs a500 electronic lockup
Old 05-31-2012, 03:49 AM
808_Indy's Avatar
808_Indy
808_Indy is offline
You're great thanks again +2 for you 1 for the info and 1 for not calling me an idiot about the Durango
Old 06-05-2012, 02:53 PM
808_Indy's Avatar
808_Indy
808_Indy is offline
So to get this correct is the A500/46rh is found in v8 rams, ram vans, and dakotas and there is nothing special to change when doing the swap into my v6 94 dakota. Same torque converter starter and such? Do I have to change the speed sensor at the bad of od unit?
I just dont want to buy the wrong damn trans AGAIN.
THANKS in advance for your help.
Old 06-05-2012, 06:47 PM
dobaroy's Avatar
dobaroy
dobaroy is offline
Indy, seems like it would be the best for you to try to find an A500 trans 1995 and older, then everything is gonna line up and fit. Good luck.
Old 06-05-2012, 07:25 PM
808_Indy's Avatar
808_Indy
808_Indy is offline
Thanks for stating the obvious there. What I'm asking is... Are the 91-95 ram v8s a500/46rh.
Old 06-05-2012, 11:16 PM
BlackDak12's Avatar
BlackDak12
BlackDak12 is offline
Default crazy
Originally Posted by Crazy4x4RT
The 46rh will be a direct swap. Rams, Ram Van, Dakotas 92-95. Durangos didn't come with the 46rh since they came out in 98? something like that.
Whats the difference from the earlier dakotas? thanks.
Old 06-06-2012, 02:01 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Crazy4x4RT is offline
The A500/42rh is a V6 only transmission. The A518/46rh is mostly V8 very few V6's on Dakotas only V8's.
Speed sensor swaps over. Use your engine specific torque converter.
Little info is known of the early years. They might not be any difference, there may be. I rule out the early years due to I don't know.
Old 06-06-2012, 11:47 PM
BlackDak12's Avatar
BlackDak12
I have a 91 v8 with an a500 in it. It dont work but its still there
Old 06-09-2012, 01:33 AM
808_Indy's Avatar
808_Indy
808_Indy is offline
Sweet I found a 95 v8 that I can get the tran from.
Old 06-09-2012, 07:49 AM
dobaroy's Avatar
dobaroy
dobaroy is offline
Just a reminder that the V8 doesn't come with a 500.
Old 06-09-2012, 08:47 AM
volaredon's Avatar
volaredon
volaredon is offline
Don't kid yourself. Seen plenty of them equipped that way.
What you say is "most" true in full sized pickups; there are plenty of Durangos Dakotas Grand Cherokees and even full sized vans I have seen with 318s in them,that do have the 500-based trans instead of the 518...
but what you say, 'should" be true if only on a common sense type basis.
I now have 2 518s here, one dead, one "supposed to" be good, the "supposed to be good" one is going into my 94 3.9 truck.
Quick Reply: A500 hydraulic lockup vs a500 electronic lockup
