Sway bar mounting plates.
Old Jul 11, 2012 | 11:16 PM
Dodgeman1990's Avatar
Dodgeman1990
Default Sway bar mounting plates.
Does anybody have a set of the plates that the sway bar bolts to? I have a 93 2wd v6 and it didn't come equipped with a SB. the plates (?) Bolt to the inside of the frame rails just behind where the bumper corner mounts connect to the frame. Or maybe even the dimensions of the plates. Probably just 2 "L" shaped pieces of metal right?
Old Jul 13, 2012 | 09:44 PM
Crazy4x4RT's Avatar
Crazy4x4RT
If I remember right www.jcw.com sells complete kits for sway bars. Your next best option is your local junkyard or www.ebay.com or www.craigslist.org
Old Jul 14, 2012 | 12:30 AM
9652dakota's Avatar
9652dakota
wow i don't think i have ever seen one of these without a sway bar. not that i have payed much attention though. i take that it handles like crap?
Old Jul 15, 2012 | 04:46 PM
siggie30's Avatar
siggie30
It is not very responsive. The previous owner deleted mine as well, or it came without. Like everyone else, I just need to go to the pickyard and get one.
Old Jul 28, 2012 | 03:37 PM
siggie30's Avatar
siggie30
Just a bump for you. I went to the bone yard today to get a anti-sway bar. Got home with everything, and discovered the "brackets" are different from my 89, and your 93. So, yes I have a set of brackets if you need them.
Old Oct 16, 2012 | 05:01 AM
wesmc55's Avatar
wesmc55
Hey siggie30..........
Are we talking about the Rear sway bar here? I want to mount a rear sway bar on my 92 and 94 Dak's. But the aftermarket kits are about $200. I was looking for a cheap way to add the rear sway bar. I live near Dallas, TX and most of the pre 97 trucks have gone to the crusher. At least in the yards I've been to. Thanks for any advice.
Old Oct 16, 2012 | 08:04 AM
siggie30's Avatar
siggie30
Well, if your a purist, then I cannot help you, however, if you are able to get a Durango rear sway, then that would be my "Factory" option.
Old Oct 17, 2012 | 12:00 AM
moparnut38's Avatar
moparnut38
I have one of those rear sway bars that I picked up off a dakota at my local salvage yard. I havent put it on my truck yet so I will go get a couple of pics for ya and let ya know
Old Jan 5, 2013 | 06:32 PM
Dodgeman1990
PM sent
Old Jan 5, 2013 | 11:05 PM
Idmtboy's Avatar
Idmtboy
You want to be careful, mounting a sway bar from different vehicle on your truck. Sway bars are designed for each individual application and one that is too stiff will get you into trouble real quick.
After driving a rig for a while, you will be able to recognize it's tells,for when you have pushed it too hard in the corners and know when you have reached it's limits and need to back off, a sway bar designed for a heavier rig with stiffer springs and shocks will eliminate those tells and you will find that the corner you used to take at 60 will have you rig breaking loose at a much slower speed without warning, because you can't reduce body roll without reducing tire grip.
