HELP Trans Issues
on
1 Post
sorry to thread jack, but mine is doing the same. someone had mentioned here before that it could be the tranny filter. well the code for the OD solenoid came up a while ago, did a tranny filter kit in hopes i could skip by it, but to no avail. Now what i am wondering is where is the solenoid? I know its in the pan somewhere, but is it easily accessible? Mine is also the 42-rh, in my 93 v6 2WD. Sold the 93 v8, body was too rotten. Bought a 99 alero v6, gave it to the gf, and took my old dakota back (for those who remember who I am).
Trending Topics
on
1 Post
Update: I'm slowly tracking the problem down. As I was just in the tranny pan a few weeks ago doing a tranny filter change, I took a look at my solenoid and all the wiring inside of the pan and all was good. Everything looked brand new in there almost. After I got the pan back up and everything, I took the 3 pronged connector apart and cleaned it up. Still no o/d. When I'm on the highway doing 100 km/h, and I hit a decent sized bump, it sometimes will shift into o/d, not all the time tho. Crazy4x4RT has mentioned before about the coolant temperature sensor being faulty causing this problem. My problem is looking more like the wiring is the problem and not the actual sensor. I'm going to be tearing into the truck today after my morning coffee to see if I can track it down to that sensor or not. We will see what happens and I will let you guys know!
