how do I remove starter 1993 V6
Ben, something must be different between the V6 and the 5.2 cause we just re and re the starter today on our 5.2. It came out from the bottom just by jiggling it around a bit. Hope somebody can help you, good luck.
2wd or 4wd?
STARTER REMOVE/INSTALL—3.9L/5.2L
TWO-WHEEL DRIVE MODELS
(1) Disconnect battery negative cable. Raise and
support vehicle.
Fig. 1 Starter Remove/Install (2.5L)
8B - 4 BATTERY/STARTER/GENERATOR SERVICE
(2) Remove starter lower mounting nut and lock
washer. Then remove starter upper mounting bolt
(Fig. 2).
((3) Move starter towards front of vehicle until
starter gear housing nose clears bellhousing. Then
tilt starter nose downwards past exhaust pipe (Fig.
3).
(4) Remove nuts from terminal adapter for starter
battery lead and solenoid lead connector (Fig. 4).
(5) Remove starter motor.
(6) Reverse removal procedure to install. Torque
starter hardware as follows:
² starter mounting bolt - 68 Nzm (50 ft. lbs.)
² starter mounting nut - 27 Nzm (20 ft. lbs.)
² battery lead terminal nut - 10 Nzm (90 in. lbs.)
² solenoid lead terminal nut - 2.5 Nzm (22 in. lbs.)
FOUR-WHEEL DRIVE MODELS
(1) Remove battery negative cable. Raise and support
vehicle.
(2) Remove front axle skid plate, if so equipped.
Refer to Group 13 - Frame and Bumpers for procedure.
(3) Remove lower starter mounting nut and lock
washer (Fig. 2). Access from front of vehicle with a
long extension.
(4) Lower vehicle and remove the 15mm intermediate
steering shaft coupler bolt (Fig. 5).
(5) Rotate coupler clip on the steering shaft and
slide upper half of shaft toward the rear of vehicle.
(6) Remove upper starter mounting bolt.
(7) Move starter towards front of vehicle until it
clears lower mounting stud, then lift upwards to gain
access to wiring connector (Fig. 6).
(8) Remove nuts from terminal adapter for starter
(9) Remove starter motor.
(10) Reverse removal procedure to install. Torque
² intermediate steering shaft coupler bolt - 47 Nzm
(35 ft. lbs.)
support vehicle.
(Fig. 2).
3).
vehicle.
long extension.
(35 ft. lbs.)
OK thanks, I'm searching now for these two items and will give it a try.
I removed the top bolt (see Picture) and the short shaft slides 1/4'' in each direction so I put the bolt back, at the bottom of the picture there is something that looks like a star or allen bolt, but i did not try to remove it. Let me know if this is what needs to be removed. Thanks
OK, I got it out by removing the fender shroud, I removed the tire and folded the flap down (took 5 minutes). Thanks everyone.
Trending Topics
I have had the starter out of both my 93 V8 truck and my 94 V6 truck numerous times and never really had an issue doing so, I never had to pull the steering shaft or fenderwell to do so, done all from underneath. I definitely dont see (by my trucks anyway) how people have such diffuculty pulling a starter from one of these.
The only issue I see is if you arent familiar with them pulling the wrong bolt out from the top of the starter; jsut above the starter there's another bolt that takes the same wrench size that goes thru the block into the tranny... and by "feel," its sometimes easy to remove the wrong bolt by mistake.
When the one went bad in my 94 I tried putting an old style "whiney" Mopar starter like they used from the 60s til the mini starter came out in the late 80s and that certainly wasnt happening I'd have had to jack the motor and pull the driver side mount to put the big starter in I can imagine doing taht in a parking lot somewhere (screw that) so I had the original starter from that truck rebuilt and reinstalled it.
I was gonna use a "big" starter since I have a few collecting dust and I wouldn't have had to put out the cash for either a reman or a rebuild of the original....
