1995 Dakota dies
1995 Dakota dies
I have a 1995 Dakota SLT 5.2, and the trucks runs like a champ down the road and pulls just fine. However, when at a stop and I press on the gas just a little, the truck acts like it is going to die and most of the time it does die. It does not matter if it is in forward or reverse. However, it does it more when pulling a load. It is the biggest problem when I am attempting to back a boat in or parking a camper. It starts right back up every-time. I changed a TPS as it looked like the same problem another member was having. It did not fix my problem. I ran the codes and the only thing I got was something I never seen (tmg temp-58). Please give me some ideas of things that I could try. Thanks for any help
Mine is doing the same thing. I changed plugs, wires, distributer cap and rotor, and cleaned my IAC. Still doing the same thing. I pulled an ignition coil from a junk yard to see if it would get better and that coil must have been bad, cause then it died constantly. I don't know if it is my coil, but i may try that next and then probably the EGR. Do you have a code reader?
Funny thing is, i just called the dealer for the coil yesterday and he said he couldn't find one. Thought that mopar must have quit making it ?! I was like, ok really?
Then someone said that AC/Delco part took place as OE part or something. So i am currently trying to find an OEM IC, since the dealer is useless. Don't want cheap parts store IC, had that experience on older vehicle. Was good for like 3 months
parts stores have several different price points; get a good well known name brand like NAPA/Echlin or BWD or STANDARD and you will be just fine.
I have been quite disappointed with OEM parts the last 2 times I have gotten them...
Rotors for my Cherokee// Made in China> had same part number as parts store cheapies stamped into the edge for double the price; clockspring for same Jeep came from Taiwan and I went directly to the damn dealer to get them and yes the boxes did say "MOPAR" on them so I will not make that mistake ever again. if I'm not gonna wind up with American made I ain't gonna waste the money on paying dealer prices
Well hell, that might be why the dealer told me to look at Advance. He knows the contracted the part out to crap vendor.
How about Delphi, also AC/delco shows up at Orielly's. BWD is ok? I thought the were not good? Richporter shows up at Advance. Any feedback on them, never heard of them. Only ask, because they are a little more expensive.
Trending Topics
MSD is typically a high quality brand. But for some reason the coils for Magnum engines are very low quality and usually fail quickly. Mine died after 3-4 months.
Some say the Accell coils are the same. I had mine on for 3-4 years, with no problems. But swapped it out for a OEM 5.9 coil just to be on the safe side.
