manual/power windows
Old Jan 20, 2013 | 05:19 PM
vtlogger's Avatar
vtlogger
Default manual/power windows
has anyone swapped manual to power windows on there dakota's . i have a chance to get some really nice door's for my truck (mine are rusted).. but they have power window and mine are manual..i would really like the power window's can they be wired or is the wiring there to power the windows??
Old Jan 20, 2013 | 07:12 PM
kahanabob's Avatar
kahanabob
i swapped in a 90. are there switches in the interior door panel? if so just have to run a hot wire and ground to each door. if no switches then just install a couple in the cab, put mine on the front face of the center console.
Old Jan 20, 2013 | 09:39 PM
volaredon's Avatar
volaredon
I have seen writeups on this and it is pretty easy; i have also swapped between power and manual doors on other vehicles (NOT a Dakota) before but I cant see doing that on a Dakota being any different of a process... usually I have a power window vehicle and all I can find in the yards are manual doors so I gotta fish the wires thru and change the window regulators... just be sure that they UNHOOK the wiring from within the body rather than to cut it... if anything, cut on the truck side of the harness rather on the door side; if they cut your wires you may as well put your manual window stuff in those door shells
Old Jan 21, 2013 | 12:31 AM
marcar1993's Avatar
marcar1993
It can be done if you want, just wire up switches to a switched power source. However, the manual regulators will bolt right in place of the power ones in 10 minutes.
Old Jan 21, 2013 | 07:02 AM
vtlogger's Avatar
vtlogger
thanks guy's ...yes door's have switch's in them.. and i'm going to be the one removing them .. so hopefully i don't screw it up!! i would swap up my stuff from my door's but when i roll up the dr's side window it bind's. so that's the reason for the swap..not sure who the last guy was to post but you have the same truck as mine!! hope to put 33s on it soon
Old Jan 21, 2013 | 08:25 AM
marcar1993's Avatar
marcar1993
Yeah, there seem to be many std cab short bed black dakotas. How are you lifting your truck to fit 33's?
Also, check, I'd almost bet that the window is whats binding on the way up, not the regulator. Take it out an crank it around. If it moves free there's nothing wrong with it.
Old Jan 22, 2013 | 04:12 AM
vtlogger's Avatar
vtlogger
not sure on the lift .. that was going to be my next question..what would i need to get 33s under it?? don't mine doing some trimming.. it need's some body work anyway..as far as the window i think it has something to do with owner be for me welding the door latch in place..not sure why he did that?? but if you pull on the door handle as you roll up or down the window it seam's like it bind's less..don't know?? but i do like the thought of power window's.... hey has anyone mounted a winch on there dakota?? how you do it?? thanks
Old Jan 22, 2013 | 02:07 PM
Crazy4x4RT's Avatar
Crazy4x4RT
To fit 33's on a 4x4 is not hard a body lift with the torsion bars cranked or get lift keys and an Add A Leaf kit for the rear. Check the FAQ2 (just a few posts above this one) for tons more lifting ideas plus how to's on it all and where to buy the parts.
For winch yes a few people have, including myself. I built my own front hitch and just use a hitch winch setup so it is removeable to the rear if needed. Check the FAQ2 for my write up on it all.
Old Jan 23, 2013 | 04:06 AM
vtlogger's Avatar
vtlogger
t-bar's have been cranked ..not sure how much..last owner did that. but when i got it there were 32s not it ..not in the best of shape so i had a set of 31s so i put then on.. do you think 2" will be enough?? ....NICE write up on the winch!! i can see i'm going to spend a lot of time under this truck ...just need it to warm up a bit!!
Old Jan 23, 2013 | 11:59 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Thanks. Yes 2in will do. Spring will be here before you know it. This is the time to buy the parts then install them when the nice wheather comes.
