old dakota with newer brain
Old Feb 9, 2013 | 08:30 PM
capricorn's Avatar
capricorn
New Member
Default old dakota with newer brain
I know I've seen this discussion before. I have a 90 that had a 3.9 and I replaced the engine and transmission from a donor 92 that had a 5.2 with auto. Now I'm going to a H.P. 5.9 that is on my engine stand until the end of this month along with a Mopar performance ECM for a 94 1500/Auto.
Now I know that I will experience a check eng. lamp code for a transmission temp. sensor and I know there is a way to fool the ECM with a transistor. I have installed a dedicated transmission cooler and fan that has a trans. temp sensor and have a separate sensor for my transmission gauge. I don't know if either of those will do to take the place of a transmission temperature sensor. I also don't know which pin on my ECM looks for that sensor input.
I know Crazy 4x4RT posted a wiring diagram and info for this quite a while back but I can't find it. Can this be reposted?
Old Feb 9, 2013 | 10:47 PM
Crazy4x4RT's Avatar
Crazy4x4RT
All you need is a 1/2W 1k Ω resister. You can buy a pack of 5 for $1.00 at Radio Shack. Here is my post on it. https://dodgeforum.com/forum/1st-gen...omputer-2.html
You might be able to wire in your temp gauge sensor, it depends on its resistance value at temp. The chart in my post has the ratings, if your sensor falls withing range your good to go.
Don't forget to post up some pictures so we all can see what is going on.
Old Feb 10, 2013 | 11:40 AM
capricorn's Avatar
capricorn
New Member
Thanks Crazy I guess that is showing pin 42 as the signal on the ECM and I'm not sure how to read the line in the diagram that says black and points to pin 21? then it appears it points to pin 11? Which pin is used for ground?
Old Feb 10, 2013 | 12:04 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Yes 42. I had it listed in the text if you needed so you don't have to read the diagram.
The Black text in the pin-out picutre is refering to the color of the connector. The ground wire is pin 11+12 Black/tan wire.
I just grounded it to the inner fender.
Old Feb 10, 2013 | 07:16 PM
capricorn's Avatar
capricorn
New Member
10/4, pin 42 and to ground. Thank you mate.
Old Feb 10, 2013 | 08:34 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Yes but you have to have a 1k resister on that line from ground to pin 42.
