4 cyl drive train, v6 engine?
Old Mar 20, 2013 | 09:49 AM
  #21
keilkravec's Avatar
keilkravec
it might be, not sure, look at the drivers side of the fuel rail where the lines are on it, if there are 2 lines coming off the rail, its a return system and your lines are already there. If its just 1 line then you'll need to run the extra line
Old Mar 20, 2013 | 11:37 PM
  #22
JCraven94's Avatar
JCraven94
I'm in luck! the 2.5 runs a return line. One more thing crossed off the list. One final question. Does anyone know if the I4 and v6 clutches are the same?
Old Mar 20, 2013 | 11:42 PM
  #23
JCraven94's Avatar
JCraven94
Nevermind I found the info I needed. The v6 has a bigger OD. I'm assuming im gonna have to replace the I4 with the V6 one?
Old Mar 21, 2013 | 11:29 AM
  #24
ricekiller's Avatar
ricekiller
the 4cyl one... if it will even work, won't hold up to the extra torque. i've never really played around with 4cyl trucks... no point.
