bleeding breaks not working
Old Jun 9, 2013 | 09:29 PM
DaisyDakota's Avatar
DaisyDakota
Angry bleeding breaks not working
ok so i had to replace my caliper in the truck and i bled the brakes before and no problem but this time around its not going to well. i turn the truck on and the pedal goes to the floor and my wife is doing that while i open the valve and its not gettin better but when i have it on accessories it stiffens up. when i turn it on again it goes to the floor, and repeat still same problem iv gone through 2 bottles now and getting frustrated. any ideas or reasons am i doing it wrong? and i cant get my pics to upload still new here haha.
Old Jun 9, 2013 | 11:02 PM
DaisyDakota
my bad for the typos "brakes" but still need help i need it running ad stopping by tomorrow so please help
Old Jun 10, 2013 | 01:26 AM
BKCowGod's Avatar
BKCowGod
Let's make sure you're going through all the steps in the right order...
Start on the passenger rear, then driver rear, then passenger front, then driver front (someone else chime in - do these have a proportioning valve that needs to be bled too?)
On each caliper, do the following procedure with the truck turned off. It is crucial that the pedal is on the floor (or being pressed towards the floor if it can't hit the floor completely) whenever the bleeder is opened.
1) Pump pump pump pump pump pump pump pump pump pump (that's ten pumps) and keep the pedal on the floor.
2) Crack open the bleeder valve, then close the bleeder valve after the flow stops.
3) Return to step 1. Repeat until no bubbles. If you wanna be sure, pick up some ATE Super Blue brake fluid. The different color makes it really easy (and it's really good, but expensive, fluid). Periodically check the master cylinder to ensure it has enough fluid.
4) Close and tighten the bleeder and move on to the next caliper.
If you have been doing all these steps properly and it's still not working, then you have a bigger problem - leaky MC or something.
Old Jun 10, 2013 | 01:44 AM
DaisyDakota
awesome dude thanks ill do that as soon as i can thank you for your help.
Old Jun 10, 2013 | 01:55 AM
BKCowGod's Avatar
BKCowGod
My pleasure... I edited to point out that if the pedal can't be pushed all the way to the floor, it's okay - as long as your helper doesn't let it UP with the valve open.
This was my first job when I was 6 years old, helping my dad do brakes on his Mustang GT. I still get nostalgic when I bleed... Literally one of my earliest memories was shouting "1-2-3-4-5-6-7-8-9-10 FLOOR!" and him shouting "OPEN - CLOSED"
My kid is 12 - way past the age where he should be helping me! Maybe I'll have him do the valley pan gasket and ported throttle body install for me. Can't be too hard, right? :P
Old Jun 10, 2013 | 02:01 AM
DaisyDakota
ya same here when i was young i was always helping my grandpa with the tractor or the truck i have now and one and a while the old land cruiser haha. but ya start them out young its a good thing to get into of you make it a profession there is good money but not only that, doing what you love. shouldnt be to hard for him he can fit in the bay and get his hands in all the tight spaces hahahaha.
Old Jun 10, 2013 | 11:06 AM
cd36's Avatar
cd36
One note, I find it helps if I close the bleeder before the flow stops. If you close it before the flow stops you are closing it under pressure, and there is no chance for air to get sucked in. If you just open the valve and let the flow stop you could potentially let air back in.
And make sure you always have a full reservoir while bleeding, check every couple of bleeds.
Old Jun 11, 2013 | 02:52 PM
DaisyDakota
Thanks a lot guys it really helped i never had any problems with until now, everything that is on it is still what came with the truck eventually it will all be changed. thanks again guys.
