Trailmaster Kit
thanks for the tip i know they are discontinued didnt know if there was a special place you can find used ones or somthing.
Im planning to do a 4bt swap with a nv4500 so i may just do the 2 in lift w/the the spacers and add a leaf and then do a 2 in body lift. since it will help with the tranny clearance etc
I have a 95 dakota I4 5 spd too
As far as what to look for, just look for the pieces in place. Here is a link to a Trailmast kit installed on a junkyard truck, sad to say it is long gone by now. https://dodgeforum.com/forum/2639822-post12.html
For a 4bt you will want stronger parts than the stock setup. A Solid Axle Swap is your best bet.
SAS is def a plan probably a posi 9.25" in the rear im only 2wd now so maybe a dana for the future front one art some point..
also for some reason my truck decided it doesnt want to start....i can hear the pump going, i replaced the ASD relay and the splice ine bay is perfect still, yet the pwoer to my ignition goes in and out and its not strong enough to crank the car
Trending Topics
I'm curious, what's the big difference between the 2WD and 4WD frames? I mean, he'd be cutting all the brackets off down to the bare framerails to do the SAS, anyway. And he's going to have to move the crossmembers and change everything around to do the 4BT/NV4500 swap. So, I can't really see how having a 2WD frame is going to make much difference. The extra little bit of fab work that might be required can't be more difficult than a frame swap, can it?
I thought the same exact thing until I looked at the to frames.. I have a 2wd body on a 4x4 frame.. The main reason behind going w the 4x4 frame is the 4x4 has a gear steering box where the 2wd has a rack and pinion and the other thing was the cross member on the 2wd is right under the oil pan where the 4by cross member is directly under the radiator support much easier to work w n build off of if u want a recovery point n or build a leaf spring set up.. My opinion tho..
This is how I built mine..
My hitch receiver is right under the plastic n doesn't look to tacky
