New 90 Vert Owner - Engine Swap
Old May 4, 2017 | 10:21 PM
  #181
ragged89's Avatar
ragged89
Mind if I share those two pictures with the Dakota Convertibles FB group? Just the pictures, no names.
Old May 5, 2017 | 07:47 AM
  #182
robertmee's Avatar
robertmee
Sure, no problem....I'm not on FB, but the wife is, so give me the FB link, and she can pop in there and respond.
Old May 5, 2017 | 10:52 AM
  #183
ragged89's Avatar
ragged89
Dodge Dakota convertibles: https://m.facebook.com/groups/56219691413?_rdr
Tried to make it a link, but it wouldn't display. Maybe because you have to be logged in to FB to get to that address.
Old May 16, 2017 | 06:49 PM
  #184
robertmee's Avatar
robertmee
I can't seem to catch a brake (misspelling intended)...so after a dozen attempts at bleeding the brakes, replacing MC and booster it appears that my new Cardone Mc off the shelf is bad out of the box. Then to make matters worse my transmission pump went south and now I'm faced with yanking the tranny. On the road was short lived. Next time remind me to replace everyrhing....the pump was about the only component I reused in the tranny build
Old May 16, 2017 | 07:38 PM
  #185
93 ragtop's Avatar
93 ragtop
Have you considered raising the stall, while you have the transmission out? How did your exhaust turn out?
Also, when I replaced my brake lines, (all of them) I had trouble bleeding the rears. I used a vacuum bleeder (harbor freight) and this has always worked well flushing, but I just couldnt get a solid brake to the rear. I had a retired mechanic who told me to get someone to push the brake pedal down, and for me to open the bleeder. As soon as it stopped bleeding, close the bleeder. Then let the brake pedal up, but do not pump. Again push down and I would open the bleeder, etc. repeating this several times. It worked.
Hope you get it back on the road soon.
Old May 16, 2017 | 08:13 PM
  #186
robertmee's Avatar
robertmee
TC was new custom from TCI...has a 2600 stall already. Your method of bleeding is what I did first....several times....then I went to the bottle filled with fluid method and went through 2 quarts of fluid. Still no go. I think the MC is bad out of the box.
Old May 17, 2017 | 05:03 AM
  #187
93 ragtop's Avatar
93 ragtop
OK I did not realize you already had a higher stall converter. They really make a difference especially with a cam change. (course, with your other vehicles and experience, I feel sure you already know that!!)
Again, this is just my opinion, but the quality of parts has gone down hill, so much , just in the last few years even.
Off topic, but one of the toilets in my home has a bad flush valve assy. So I ordered one that is supposed to be a OEM part. $35.00. (American Standard) Well it has a small leak where 2 pieces of plastic are sealed together.
Quality, even in brand names is hit and miss anymore. IMO its because a lot of these brand name items are now being produced in china with inferior quality control.
Hope you get that master cylinder figured out.
BTW did you go with true dual exhaust? Pipe size? mufflers?
Old May 17, 2017 | 08:08 AM
  #188
robertmee's Avatar
robertmee
I did alot of reading on exhausts...performance vs loud vs obnoxious noise in a vert vs space limitations because of the gas tank location. I have the 22 gal tank so it takes up alot of space....couple that with the driveshaft and Trasmission cross member there isn't s whole lot of room.
With all that into consideration I went with gutted cats...2.5 inch pipes into a dual in dual out flowmaster....the dual acts as an h pipe for balancing purposes and it fit nicely next to the gas tank. From there 2.25 to 3" chrome tips out the back. We toyed with side discharge and under bed hidden but in the end the wife wanted the duals out the back. I'm not racing the truck just want it to sound mean so the little hit of perforce loss of single mufflers was worth the aesthetics and cost.
Old May 20, 2017 | 02:22 AM
  #189
shadowthedakota's Avatar
shadowthedakota
Check the porportioning valve. My 89 has an issue where the rear brakes are shut off due to a leaky
Old May 26, 2017 | 12:16 PM
  #190
T.C.'s Avatar
T.C.
I just have to say that was an excellent thread, good job on your build. It just makes myself want to work on my truck build now.
I do have a couple of questions about your swap.
1) Did you ever dyno the 360, how much are you making? Do you know any tips and tricks for the engine that I have yet to realize?
2) You discussed that you swapped out the TC, since this is my first ever build, having a higher stall converter worth it, and worth the time and money?
3) The reason you went to Carb instead of mpi, is due to simplicity? Through your research were you able to find tune-able efi that could work with our wiring and or sensors, or should I redo everything.
Anyways that is an amazing build, and engine swap. I will be sure to submit my build soon enough.
Here is my engine that I rebuilt, I swap is happening at the end of June. It has jpeg heads, long tube headers, comp cam, aluminum mpi intake, S.A. Gear performance timing set with tensioner and a bunch of other stuff.
Attached Thumbnails New 90 Vert Owner - Engine Swap-16997753_10209749034295816_3563187456257075857_n.jpg
