Fuel Pump Petered?
Old Aug 24, 2013 | 10:28 PM
KevinSandidge's Avatar
KevinSandidge
Default Fuel Pump Petered?
Hey fellas; my '94 started, immediately died and won't restart. it has high miles and probably about time for the pump to go out. my question is, can the pump just suddenly go out like that with no prior warning? i'm real tempted to order one tomorrow........so i can then find an electrical problem the day the new pump arrives thanks
Old Aug 24, 2013 | 10:37 PM
vhinze's Avatar
vhinze
If you slug the fuel tank with a two x four or a soft hammer, the blow will often get a freshly failed fuel pump to run for a short while. If that does not pan out, try addressing "The Splice" as detailed in the sticky.
Old Aug 24, 2013 | 10:51 PM
moe7404's Avatar
moe7404
should have been using Marvel Mystery Oil. LOL 4 oz to 10 gal of gas.
Old Aug 24, 2013 | 11:37 PM
KevinSandidge
i forget about marvel; i think i'll need some for the bed bolts
Old Aug 24, 2013 | 11:41 PM
KevinSandidge
Beat on it first; number one rule for shade tree mechs my helper didn't show today to help with electrical but i'll give it a good whack tomorrow. thanks much
Old Aug 25, 2013 | 10:54 AM
Brian in Tucson's Avatar
Brian in Tucson
Yeah, it can go out all at once. Did you run it out of fuel lately? The fuel pump is cooled and lubed by the gas it pumps. Running it dry is a no-no.
Are you showing any engine codes?
Old Aug 25, 2013 | 03:11 PM
KevinSandidge
thanks; no, i'm careful not to run the gas low cause my indicator is broke and now the speed and trip meter too :/ i've not heard any noises but my check engine light's been on for a long while. can't afford a diagnostic. thanks; i'm really not wanting to unravel all those wires is why i'm gonna probly go on assuming it's the pump...150000 miles on it.
Old Aug 25, 2013 | 03:49 PM
KevinSandidge
Tried the 2x4 procedure and got it to run..yeah! got it home now in the shade. So i'd be risking strandation if i try and run to the store and back eh? at least i know it's the pump and not the wiring!
thanks for the helping hand
Old Aug 25, 2013 | 09:33 PM
Cooreman's Avatar
Cooreman
Turn your key on and off five times and leave it on the on position the engine light will flash your codes ending in 55 meaning there are no more codes
Old Aug 26, 2013 | 01:40 PM
KevinSandidge
didnt know that; thanks!
