What are the gear ratios in front Differential
Old Oct 3, 2014 | 10:56 PM
DAKOTASPORT19954X4's Avatar
DAKOTASPORT19954X4
Default What are the gear ratios in front Differential
I drive a 1995 dodge dakota sport 4x4 5.2 v8 5spd what are the front gear ratios on that type of truck with the v8 5spd and being a sport edition because when i bought this truck the four wheel drive never worked so i decided the other day to pull the front differential cover off and the pin in there was sheared off and the gear that locks and sends power to the wheels was absolultey trashed there was shavings and pieces every where in the differential so now i need all new gears for the front differential so i need to know the ratios for the front end if anyone could help i would gladly appreciate it oh and by the way the sticker that tells all this on the hood when you open it up has been ripped of so i have no idea what kinds of stuff my truck has example the gear ratios so hopefully some one knows so i can get it fixed.
Old Oct 4, 2014 | 01:40 AM
ragged89's Avatar
ragged89
Front diff should match the rear diff. Check for the tag on the rear end; should show the ratio. I believe the standard was 3.55 to 1 and most 4WD Daks have that. 3.90 to 1 was an option.
I believe I have those ratios correct, if not, someone set me straight.
Old Oct 4, 2014 | 08:44 AM
92DakotaClub's Avatar
92DakotaClub
my 5.2 4x4 was 3:55 ..... you can check the glovebox or underhood sticker it will give what gear ratio you have or vin # and call the dealer they will have the info
Old Oct 4, 2014 | 10:24 AM
SteveDes's Avatar
SteveDes
There is a link in the fAQ section to get a build sheet from chrysler, it will tell you everything.
Old Oct 4, 2014 | 01:00 PM
Tom A's Avatar
Tom A
Section Moderator
If you already have the cover off, the ratio should be stamped into the ring gear. Worst case, count the teeth on the ring gear and divide by the number of teeth on the pinion. My guess is that they're 3.55, though.
Old Oct 5, 2014 | 11:50 AM
DAKOTASPORT19954X4
Thanks for the help.
Old Oct 5, 2014 | 12:16 PM
Mega-Hemi's Avatar
Mega-Hemi
http://www.dodge.com/webselfservice/dodge/Recall.html
Click "equipment listing" on the left. Put your VIN in the spot provided and click "Search".
Old Oct 8, 2014 | 08:09 PM
Brian in Tucson's Avatar
Brian in Tucson
I'm not pretending to be the grammar police, but your posting left me (mentally) breathless.
Punc. tu. ation!
Wish my truck had a 5 speed, I think.
Old Oct 8, 2014 | 10:53 PM
DAKOTASPORT19954X4
I'm sorry Brian in Tucson for not using punc. tu. ation.
