Truck won't crank after transmission fluid change
1993 Dodge Dakota 4x4 5.2L
Just as the title says, my truck will not crank after I just changed the transmission fluid/filter. It is currently on jackstands. I tried to start it to get the fluid going to check for leaks before I put the front driveshaft back on, but she will not crank or turn over. All lights come on in the truck, nothing happens when I turn the key full on...
Please help!
Please help!
well, the truck starts now. The linkage is messed up for some reason.
My father and I tried to start it in park or neutral and nothing, but noticed the reverse light was on when in Park. I put it in Reverse, and it started (the truck thinks its in Neutral when in Reverse). In Neutral the truck is in Drive.... I have no idea how this happened as I did not touch any linkage while replacing the fluid.
Is a simple adjustment needed or is there something else that has to be done?
An adjustment of the Neutral Safety Switch on the transmission. It may be called by something else, but it's the switch that tells the rest of the car that you're in Neutral or Park.
Also, typically does the reverse lights on later transmissions, dunno about the '93 wiring.
(Those are separate switches on my 1988, but the same switch on my 1991 Cougar.)
RwP
RwP
How did you raise it? Dakota is a framed rig, not uni-body, right?
Some T-case linkages and Trans linkages have mounts on the body, and the drivetrain.
If the body shifts, (and you have this style set up) it could very well move the linkage.
But I can only see that happening if you lifted it from the cab/body and not the frame,
or the frame and cab got twisted when raised,
or the cab mounts are so loose the cab shifted when raised.
Regardless of the cause, it's not normal, and should be checked out.
Would really suck to hit the brakes, and have the trans linkage shift into reverse.
![Big Grin](https://dodgeforum.com/forum/images/smilies/biggrin.gif)
I lifted the truck from the frame, just as I have done numerous times. Just thought it was weird that it chose this time to cause a problem with the linkage.
Now that I'm thinking about it, when removing the front driveshaft for the trans pan clearance, i may have hit the linkage... Im thinking the linkage altered then changed back as I moved the truck around... I checked all the linkage under the cab and in the engine bay, but all seemed fine. No problems with shifting since..
Changed the diff fluid yesterday and did not have the right wrench to drain the transfer case fluid... A large crescent was too bulky. Does anyone know if the drain and fill plugs for the transfer case are 1-3/16"?
Not positive on the wrench size, but I think you are right with the 1 3/16"
All my jeep T-cases use allen wrench plugs, and haven't had to mess with my '09 yet.
Trending Topics
Thanks for the reply gents. Tbugden is right, its a 30mm. Took me a long time to get the right size, then I realized I could look up a replacement plug that would give me the correct size. Looked it up on Oreily's website. Had to buy a whole wrench kit from HF since they did not sell 30mm singles.
All fluids are changed and she drives smoother than before.
