Removing viscous clutch from water pump
Old Mar 8, 2016 | 06:29 AM
dakotadave64's Avatar
dakotadave64
Default Removing viscous clutch from water pump
'92 Dakota...3.9...Is there a special tool to hold water pump pulley from turning while removing the viscous radiator fan clutch from the threaded water pump shaft? Been trying the screwdriver between the pulley mount bolt thing and that is not working.
Old Mar 8, 2016 | 08:19 PM
dakotadave64
Ok...been through two coat hangers and a can of WD40 tryin to keep water pump from turning while trying to loosen viscous clutch from water pump�� Any ideas afore I set it afire?
Old Mar 8, 2016 | 08:25 PM
RalphP's Avatar
RalphP
You've tried both forward and reverse? I don't know on a Dakota, but my Cougar is reverse-threaded IIRC.
RwP
Old Mar 9, 2016 | 04:15 PM
onemore94dak's Avatar
onemore94dak
What motor do you have? On my 94 3.9 the fan is not on the water pump. I didn't look closely and I've only had the front exposed once but this is what matters to remove the fan. I got it loose via a large cresent wrench and smacking it with a hammer no holdback. Leave the belt on until you get the fan nut loose. It only has to turn a little and it should go from there. I think it had to rotate clockwise to loosen since the motor turns clockwise and that would tighten the fan when running.
Old Mar 9, 2016 | 04:27 PM
mark38090's Avatar
mark38090
I wish I could help you but I've broken more than one over the years. I even knocked a hole in my radiator once trying to hit a pipe wrench.
Old Mar 9, 2016 | 04:34 PM
dakotadave64
Thank you all for the advice! Mark...at least you are honest! Lol! Anyway, called a local Dodge service department. They said left hand threads...but he said lefty loosely. After trying again, using special tools with no result....Looked up left hand threads...left hand threads are righty loosey.
Old Mar 13, 2016 | 01:55 PM
RobertMc's Avatar
RobertMc
FWIW: On my 90 4x4, the fan and fan clutch are bolted to the water pump and pulley with 4 small bolts.
Once the fan + clutch were removed, I clamped it in a bench vise to separate the fan from the clutch.
Of course 91 is when they made a bunch of changes... so YMMV
Old Mar 13, 2016 | 09:48 PM
marcar1993's Avatar
marcar1993
I remove the water pump with fan on it. clamp it in a vice, then its easy to remove the fan/clutch. And yes, left hand threads are reverse of what you expect.
