Manual Trans Compatibility
Old Jun 9, 2016 | 05:58 PM
blizzblang's Avatar
blizzblang
Default Manual Trans Compatibility
Are manual transmissions OBD sensitive like automatics are? Can I use a 97 5.2 manual on a 93? Or must it be the the same OBD ver?
Old Jun 9, 2016 | 06:33 PM
robertmee's Avatar
robertmee
Didn't you have a 42rh? If so trying to swap a manual in for an automatic will be alot of work...shifter changes, cutting the floor pan, possible tunnel changes, not to mention all the linkages, clutch plate, bearing change et al.
If you're talking about swapping an A578 for the A568 I'd have to ask why? The 568 is considered by many the best manual transmission.
Old Jun 10, 2016 | 08:05 AM
RalphP's Avatar
RalphP
It's not the OBD version (that's coincidental); it's the same family.
The 4xRH swap; the 4xRE swap; but swapping a hydraulic for an electronic (or vice versa!) requires control electronics that match the transmission.
(It just happened to have happened with the OBDII conversion for Dodge; Ford was already there with the AODE and 4R70W (electronic) replacing the AOD (hydraulic) around 1994.)
RwP
Old Jun 10, 2016 | 01:20 PM
robertmee's Avatar
robertmee
RwP
The 4x are autos...he's wantin to swap in a manual
Old Jun 10, 2016 | 04:32 PM
blizzblang's Avatar
blizzblang
Didn't know that was a coincidence, good to know. My plan is to set money aside and put a t58 behind my 5.9. I saw a few writeups with the R/T Dakotas, should be about the same. My end goal is to put all the pieces in a short bed convertable.
It's near impossible to find manual parts for dakotas here though, gotta get then shipped.
Old Jun 10, 2016 | 05:36 PM
robertmee's Avatar
robertmee
T58? What's that? T-56 born warner like on the srt10? Won't fit a 5.9L. Do you mean a 46RE? That's what was mated to the dodge R/T. You can easily put a 5.9L/46RE in a vert....just be sure to grab the wiring harness and ecm from the donor truck.
Old Jun 10, 2016 | 08:45 PM
RalphP's Avatar
RalphP
The T-56 can be fitted to a 5.9; they used to stick them behind the LA block 360s.
And if nothing else, you can check out what Tremec sells.
RwP
Old Jun 10, 2016 | 11:04 PM
robertmee's Avatar
robertmee
RwP
Can is the operative word....I should have been more clear...won't fit as a direct swap. Like anything enough time and money anything can be adapted. If you really want to put a t56 behind a 360 this thread details alot of the work required...
http://www.dakotart.com/forum/showthread.php?21375-viper-t56-into-99-dakota-rt
Old Jun 11, 2016 | 12:40 AM
RalphP's Avatar
RalphP
*frowns* Shouldn't be too much work.
http://www.jegs.com/i/Quick-Time-Bel...ductId=2834613
There's the bell housing to a T56. Clutch may need to be carefully picked. You should be able to use the hydraulics out of a stocker 5 speed.
Cross member may need to be tweaked or custom made; but that's pretty much a given with any non-factory transmission IMO.
Also, a custom drive shaft; but again, most folks will want to custom even if it's not a custom transmission if they're beefing it up any.
RwP
Old Jun 11, 2016 | 07:02 AM
robertmee's Avatar
robertmee
RwP
Don't forget he's starting with an automatic truck.
