Pdc box question(picture)
Old Jun 23, 2016 | 06:12 AM
bfowler92's Avatar
bfowler92
Originally Posted by Friar Tuck
Is that the original PDC? The fuel pump has to be running off the ASD relay.
As far as I kwow it is.
Old Jun 24, 2016 | 07:54 AM
SteveDes's Avatar
SteveDes
You should get the initial fuel pump power up before the pcm looks for that signal and removes the ground.
Old Jun 26, 2016 | 01:29 AM
Friar Tuck's Avatar
Friar Tuck
What you can do to see if the pump is running off the ASD relay is pull the relay out and jumper pin 30 in the socket to pin 87 (called the ASD BYPASS). If the pump comes on, problem solved, it's wired to the ASD relay and does not need a Fuel Pump relay.
Old Jun 26, 2016 | 08:12 AM
bfowler92's Avatar
bfowler92
Ok so the asd bypass was good so it should all work once the engine is in and hooked. Thanks for the help.
