Mouldings and window trim
Old Aug 23, 2020 | 04:27 PM
  #41
onemore94dak's Avatar
onemore94dak
Resurection to add note- Do not over tighten door handle nut especially on cheap aftermarket parts.
Well my passenger door handle broke. I noticed a couple months after I replaced it that there was a crack on it. I had assumed some vandal did it. run forward to the last couple weeks when I go to put groceries in it was worse ans worse off. Today as I looked at it the metal brace against the back fell down inside the door, the threads had fully broken off. Today I dug up the original one I removed (the new ones weren't worth it they were as faded as my OE handles inside a year) the broken one and installed it. I realized as I did it that I had tightened the plastic nut very tight with pump pliers. Today I did it by hand and a little with the screwdriver. I suspect it broke due to being so tight and the aftermarket $7 handle being made of cheap plastic.
Old Aug 23, 2020 | 05:48 PM
  #42
RalphP's Avatar
RalphP
Datsux, onemore94dak.
RwP
Old May 26, 2023 | 08:46 AM
  #43
DennisRawlette's Avatar
DennisRawlette
Default 1995 Dodge Dakota Window Sweeps
I have 4 Right side sweeps that I took of salvage trucks. $75.00 each free shipping. Let me know if interested. Thanks, Dennis
