Help! 92 dakota v6 3.9l died and wont start
Old Apr 30, 2017 | 09:19 PM
RalphP's Avatar
RalphP
Pull the new crank sensor, crank it and see if you get the "clicks".
That may be hitting on the torque converter or the tone ring.
Also, what brand? These vehicles seem to be twitchy as to brand; it really ought to be a Mopar OEM crank sensor (there's always people who buy the house brand ones and they Just Plain Don't Work.)
RwP
Old Apr 30, 2017 | 09:26 PM
Trevorlb90's Avatar
Trevorlb90
I can try that as well... Is it possible its a faulty hall effect sensor?
Old Apr 30, 2017 | 09:28 PM
Trevorlb90's Avatar
Trevorlb90
RwP
i think the brand was bgm from oreillys
Old Apr 30, 2017 | 09:36 PM
Trevorlb90's Avatar
Trevorlb90
Also ive been told it could either be the hall effect sensor or the camshaft sensor?
Old Apr 30, 2017 | 09:53 PM
RalphP's Avatar
RalphP
I'm not sure either of the two sensors (cam or crank) are hall effect or not; but yes, it may be either or both.
But with it clicking ... pull that crank sensor first, see if the clicking goes away. Also, that will allow you to see if the tone ring's been hitting it.
If not, check the cam sensor (inside the distributor); see if IT looks like it's hitting anything.
But before all that, LOOK for the discharge snaps. See if it's the HV output of the coil going somewhere besides the distributor.
RwP
Old Apr 30, 2017 | 10:08 PM
Trevorlb90's Avatar
Trevorlb90
I already took apart distributor earlier today... Hall effect had a bunch of gunk on it so i cleaned off terminals and put it back together... But maybe hall effect is just alltogether bad... It is a 30 year old truck after all... It looks original (old to say the least)
Old May 1, 2017 | 12:12 AM
ragged89's Avatar
ragged89
After reading that you noticed the clicking after changing out the crank sensor, my first thought was that the new sensor may be hitting the flywheel. Ralph mentioned that possibility, and the fact that you hear it at the rear of the engine (distributor area) makes it even more likely as the source of the clicking, and the starting/running issue.
The crank sensor is normally very close to the flywheel tone ring so its possible to imagine some foreign object, like a broken off piece of the sensor you changed out, getting jammed up in there. If you pull it, check the end of the sensor for signs that it has come into contact with something. When the crank sensor isn't supplying a signal the ASD disables spark and fuel.
Old May 1, 2017 | 12:27 AM
Trevorlb90's Avatar
Trevorlb90
I will check thay out tomorrow but i really hope nothing fell in there because it is all by feel... No good line of sight on the crank sensor socket
Old May 1, 2017 | 08:12 AM
robertmee's Avatar
robertmee
Process of elimination....
Remove the coil wire to the distributor and crank...if clicking goes away it's a high arc clicking. If it remains, it's a mechanical interference somewhere.
Old May 1, 2017 | 09:16 PM
volaredon's Avatar
volaredon
which are 2 names for the same part, some books call it "distributor pick up plate"
