1st Gen Towing Reliability
Old Aug 2, 2017 | 03:40 AM
  #41
Toby Warford's Avatar
Toby Warford
Originally Posted by Justin94
I live in west Tn. And at the moment I don't have the money to change it due to issues with my house.
what is cheaper though, $35 or so for the right fluid, or 2-300 or WAY More for a new transmission?
Old Aug 2, 2017 | 05:07 PM
  #42
Justin94's Avatar
Justin94
I know where a good trans is that I can get for free.
Old Aug 2, 2017 | 05:27 PM
  #43
Toby Warford
so? Whos going to put it in for you? You don't seem to have the knowledge or patience to do it yourself. How are you going to get back amd forth to wherever while your truck is being fixed?
Old Aug 2, 2017 | 05:50 PM
  #44
Justin94's Avatar
Justin94
I can install it myself. And I have a backup vehicle.
Old Aug 2, 2017 | 05:55 PM
  #45
Toby Warford
Old Aug 3, 2017 | 10:46 AM
  #46
robertmee's Avatar
robertmee
Now you're being ridiculous. So, you're okay running potentially the wrong fluid, because you'd rather chance it for $35 since you have a backup transmission. Don't know about you, but my time for swapping a transmission is worth far more than $35. And once you swap that transmission, whatcha going to fill it up with? That's right...the $35 oil you tried to avoid buying.
Old Aug 3, 2017 | 09:18 PM
  #47
Toby Warford
10:1 hed find a reason it wasnt the fluid and use dexron again.
Old Aug 6, 2017 | 12:04 PM
  #48
Justin94's Avatar
Justin94
I talked to a transmission repair shop and they advised me not to use the ATF+4 due to seal compatibility issues. They service the A500 with Dex/Merc and guarantee them.
Old Aug 6, 2017 | 12:08 PM
  #49
Chrysler recommends the ATF +4.... Think I would believe the manufacturer before I would take the word of some other shop.
Old Aug 6, 2017 | 12:11 PM
  #50
robertmee's Avatar
robertmee
We've all said the same...at this point, the OP would find a homeless guy under a bridge, and if he said use Dex/Merc that'd be good enough to justify his position. It's a lost cause at this point.
