evaporust or metal rescue?
Old Oct 1, 2017 | 10:07 AM
tbugden's Avatar
tbugden
Originally Posted by 93 ragtop
You know, I forgot all about the post of you doing that. Can you give me a link to that post? FWIW I was looking at a few sites about this method. I have a 50 gal plastic drum. My battery charger is a 2-30 amp with a 200 amp boost. I have a lot of scrap steel pipe...
​​​​​​Sure. Not sure if my pictures work anymore
https://dodgeforum.com/forum/1st-gen-dakota/369729-the-victim-build-thread-featuring-frame-replacement-5.html#post3217130
Old Oct 1, 2017 | 10:12 AM
https://dodgeforum.com/forum/1st-gen...ml#post3217130
Pics work for me. The various browsers have a new plugin out, that actually makes photobucket links work again.
Old Oct 3, 2017 | 11:06 AM
93 ragtop's Avatar
93 ragtop
OK wanted to update this post. The below part was 3/4 soaked in vinegar for about a week. (not quite enough to cover) I rinsed with a water hose and blew with air. no wire brush. The other one is as removed from the truck.
I am trying tbugden's method. For a quick test, I grabbed a old transmission mount for the sacrificial metal. and I am using one of the spring hangers as the test.
Will update on that as well
Vinegar used on right
