Idler Air Control Valve Issue
HHhmmm...... Try this trick before buying a new one....
Disconnect battery.
Turn on headlights.
Wait 3 minutes.
Turn off headlights.
Reconnect battery.
Turn ignition On, (but not to start)
Count to ten.
Start engine.
See what it does. When you reset the PCM, it needs to relearn the 'zero' values for all the various sensors. Need to give it time to do that.
Disconnect battery.
Turn on headlights.
Wait 3 minutes.
Reconnect battery.
Count to ten.
Start engine.
Disconnect battery.
Turn on headlights.
Wait 3 minutes.
Reconnect battery.
Count to ten.
Start engine.
Disconnect battery.
Turn on headlights.
Wait 3 minutes.
Reconnect battery.
Count to ten.
Start engine.
Here is my plan going forward (unless someone has a better idea). I can't buy a new IAC till Tuesday when the dealers open up again. So I'll drive it the next two days. If the problem does not fix itself by then I will buy a new Mopar IAC. I'll put it in and if it fixes the problem then I will live the rest of my life in happiness. If it does not fix the problem then I am forced to have the dealer get to the bottom of it. Might turn out it is not the IAC and I will have spent money on a new part I did not need. But my truck is 24 years old so I don't mind as much buying parts before they die. I figure they are in the twilight of their life anyway and will be one less part I have to worry about.
Thanks all for your help. I appreciate it.
Checked for voltage on the IAC plug. Two contacts with no voltage (or a trace) and other two with 12 volts each. Has to be the IAC. I was very careful when I cleaned the IAC not to twist, turn, push, pull on it. But when you remove and insert it into the throttle body who knows. You wouldn't think simply cleaning the thing would damage it. Maybe I got some brake cleaner in the thing. Like I say, who knows!
