engine miss 2000-3000 rpm
Old Jun 14, 2018 | 05:04 PM
frankbuck's Avatar
frankbuck
Default engine miss 2000-3000 rpm
engine won't rev past 2k-3k. gas gauge doesn't work (low fuel light works). When I add fuel additive, revs higher for a while. same RPM limit in any gear. runs up to 80 mph, just can't get there very fast.
rotor/cap/wires look good, pump has been replaced before. 1994 5.2 2-wheel drive
my thoughts: fuel pump or collapsed fuel line (I'm in S. California, lots of ethanol).
Any help is appreciated!
frankabuck@gmail.com
Old Jun 14, 2018 | 06:31 PM
RalphP's Avatar
RalphP
1994 - it should still have the frame rail mounted fuel filter; has it been replaced recently?
What kind of shape is the cat(s) on it?
RwP
Old Jun 16, 2018 | 12:56 PM
Snowman451's Avatar
Snowman451
Ralph, the 94 5.2 has an in-tank filter. Id look at eh cats too. I would think a fuel line collapse would cause lean condition and detonation.
Old Jun 16, 2018 | 08:56 PM
RalphP's Avatar
RalphP
Yes it does.
And you're right, I was thinking 1992/1993 which still had the frame mounted filter. Also.
RwP
Old Jun 19, 2018 | 02:54 AM
frankbuck's Avatar
frankbuck
I looked at first post, didn't explain correctly (it was late).
Truck starts missing or acting like it's hitting a rev-limiter, When adding fuel treatment, revs a little higher for a while.
Truck just passed annual smog check and when I bang on cat, it doesn't make noise. I've replaced the cat two times before, and it was really noisy.
Old Jun 19, 2018 | 09:43 AM
Failing crank or cam sensor. Maybe low fuel pressure?
Old Jun 20, 2018 | 02:29 PM
frankbuck's Avatar
frankbuck
Thanks for the reply. Already planning a fuel pump replacement (gauge doesn't work). Is there a way to test the crank or cam sensor?
Thanks.
Old Jun 21, 2018 | 09:06 AM
Not without an oscilloscope.....
