Extended lugs part number?
Old Jul 3, 2018 | 06:16 PM
gadrams's Avatar
gadrams
Default Extended lugs part number?
Hello everyone, I'm new to this forum.
I recently got my hands on a 1996 Dodge Dakota SLT extended cab. It came with gen two wheels. When I did a tire rotation I noticed the lugs nuts were threaded halfway. When I removed the wheels it had 1/4 inch spacers. I just want to know if anyone knows the part number for some extended wheel lugs for this truck. I saw some on eBay and I got the following information. Dorman 610-426, Size 1/2-20 Serrated, Knurl: .582, Lenght: 2.230. Please let me know if these lugs will be long enough. Thanks
Old Jul 5, 2018 | 05:18 PM
gadrams's Avatar
gadrams
Please someone help me figure out what type of extended lugs I need. Thanks
Old Jul 5, 2018 | 05:21 PM
Take one of your adapters off, cruise up to the parts store, (drive something else please......) show the guy what you got, tell him what you need, and he should be able to hand it to you. Trouble is, you are going to need 24 of them.... and they may or may not have that many in stock. Should be able to get them pretty quick though.
Old Jul 5, 2018 | 05:45 PM
Take the spacers off and the ones you have will seat properly.
Old Jul 5, 2018 | 05:49 PM
93 ragtop's Avatar
93 ragtop
i assume this is the front and its 4wd? Looking at rockauto, it seems this would be the orig. size. https://www.rockauto.com/en/moreinfo...087668&jsn=478
so its 2.177 in.
the ones you posted are about the same, only 5 hundred in. longer (less then 1/16th.
Old Jul 7, 2018 | 02:35 PM
gadrams's Avatar
gadrams
the spaces are there to avoid the rim from hitting the upper control arm. I read other have cut off a piece of the control arm; I'm not cutting.
Old Jul 7, 2018 | 02:38 PM
gadrams's Avatar
gadrams
so its 2.177 in.
Yes it is the front but my truck is not 4x4
Old Jul 7, 2018 | 05:05 PM
gadrams's Avatar
gadrams
Just came back from Auto Zone and Advance and got nothing. The only carry the stock and it had to be ordered.
Thanks
Old Jul 7, 2018 | 08:12 PM
93 ragtop's Avatar
93 ragtop
OK then for the 2wd, here is their listing. https://www.rockauto.com/en/catalog/...,lug+stud,7680
Says it is 1 & 11/16 so the ones you listed by dorman would be slightly over 1/2 in longer. Do you believe that is enough?
Old Jul 7, 2018 | 09:57 PM
onemore94dak's Avatar
onemore94dak
See if this helps they have several lengths. https://shop.advanceautoparts.com/fi...ota-wheel-stud
