Fire on one cylinder
Ok, I'll try to be brief. But I know the more info I give the better my chances of getting the right answer. I have a 94 Dakota sport 2wd 2 door. Originally a 3.9 auto. About 10 years ago I transplanted a 5.2 auto. I drove it for 2 years and the trans blew. It's been sitting since then. Last week I decided to pull the tarp off and bring her back to life. Put in a good used trans, and now I'm trying to get it started. Problem is, it only has spark to no.4. I've replaced the cap, rotor, and pickup coil .With no change...
Does the rotor spin while cranking the motor? And how do you know it only has spark to #4 cylinder? Next test is, is spark coming OUT of the distributor cap? If it's coming out on the other cylinders, but not making it to the plug, it's a safe bet your wires also failed.
RwP
RwP
RwP
RwP
I mean, if it dependably fires on #4 ONLY, it knows when #4 is up to fire, that proves most all of it.
And what ground would kill all but one plug?
I say it again - if the coil is firing each time, and it's not coming out of the distributor but on one wire, it's cap or rotor. That's ALL that's there to pick which cylinder it's firing at any given fire event.
RwP
Trending Topics
I've seen crank sensors short out, and randomly fire. I've seen corroded computers do all kinds of crazy things. And a bad ground can cause more problems than I'd care to list. And as stated. The cap, rotor, and pickup coil are all new
