Oil light flutters and blinks
I have 1993 Dodge Dakota V8 4x4 Le and the oil light flutters or blinks but never stays on for more then a min or two. Some of the time the light is on when I accelerate it turns off then will turn on when I break. Most of the time it is very random and stops when driving for longer. My oil pressure gauge seems to be functioning and when I check the dipstick that seems to be fine as well. Is this a failing oil pressure sending unit?? or an oil sensor?
Thank you in advance for any advise.
The oil pressure sending unit, or the connector to it.
Do remember, there's TWO units in the ONE sensor/sending unit - one for the switch, one for the gauge.
If the gauge is fine, I'd bet the connector or the sending unit WWAAAAYYYYY before I'd tear the motor down.
(I have the other problem; my light isn't coming on, but at random, the gauge drops to 0. But I KNOW the connector is farked.)
RwP
RwP
It's at the back of the block, down below and to the passenger side of the distributor.
Feel between the distributor and the EGR valve; that wiring harness goes to the sending unit. It has a clip; pull it away from the connector slightly, then pull it off, remove the sending unit, and install the new one.
Helps if you have a mirror so you can see down there.
RwP
RwP
