At Wit's End With '91
Old Apr 8, 2019 | 06:17 PM
  #51
Well, that would certainly explain a lot....... Critters cause all manner of problems..... Though it makes you wonder how they get in there in the first place.
Old Apr 8, 2019 | 08:05 PM
  #52
KevinSandidge's Avatar
KevinSandidge
yeah, i thought the thing was sealed up but there was an open port on backside of the case, i guess to help the airflow.
Old Apr 10, 2019 | 10:58 AM
  #53
90DDLE's Avatar
90DDLE
I had a "no start" issue on my '90 Dakota. After checking fuel, spark, etc., I discovered that if I bang on the ECM it would start. I could also get it to quit by banging on it. I replaced the ECM with a reman. unit. So far, so good.
Old Apr 10, 2019 | 03:19 PM
  #54
KevinSandidge
I've beaten on starters and gas tanks and i jiggled the ecm wires but never thought to beat on the dammed thing itself glad a new one fixed your ride; i'm hoping tomoro it solves mine as well.
Old Apr 11, 2019 | 12:12 PM
  #55
KevinSandidge
New ECM did not solve the problem so i give up guys. i don't relish the idea of leaving it with a repair shop but guess that's what i'll have to do.
I'm not getting a trouble code with the key light flashes; will a pro model obd1 scan tool pick up codes that the key method will not?
Old Apr 11, 2019 | 05:49 PM
  #56
A good scanner will also show you pending codes. Not to mention give you access to a LOT of information the parts store scanners will not.
Give a quick recap of symptoms, and what you have done?
Old Apr 11, 2019 | 06:19 PM
  #57
KevinSandidge
I'll get back with you on that later; thanks
Old Apr 11, 2019 | 08:23 PM
  #58
KevinSandidge
we're not getting a reading at the coil, no fire to coil. we're looking for a 'ballast resistor'. do i even have one of those?
Old Apr 11, 2019 | 08:34 PM
  #59
No power at the coil? What about at the injectors? Don't know if there should be a ballast resistor or not.....
I am going to move this to the tech section..... Like I should have quite a while ago..... Yep. I'm a slacker.
Old Apr 11, 2019 | 09:06 PM
  #60
KevinSandidge
sounds great slacker,er, i mean helpful soul. pouring gas straight into the carb did nothing.
