Transmission Band Adjustment
1993 Dodge Dakota LE, 5.2L V8
174,000 miles, original owner
Transmission: A518
I don't know if that is the correct number for the Tranny. It doesn't look like the standard "R.." number format I have seen but it is what was on the hood sticker. Not sure how I can find the correct number for the tranny. Anyhow, I have a question about transmission band adjustments. Should tranny bands be adjusted only if there is a known or suspected problem that requires adjustment or should band adjustments be a part of periodic, preventative maintenance? It certainly does not appear to be a difficult job. My bands have never been adjusted and I have no signs of shifting problems. I lean toward not touching them but I want to get some opinions.
Thanks!
Transmission: A518
Thanks!
46RH, same thing. Naming nomenclature changed over the years.
Supposedly, band adjustment is a scheduled maintenance item. (every 30K miles or so, same time as fluid/filter change) But, if it isn't a problem..... I would be tempted to leave it as well. Maybe think about it next time you do the fluid/filter.
Oh, and thanks for the model number clarification.
