mix and match fuel tanks?
Did a search got this result 3 tanks
https://www.partshotlines.com/component/phl/search/
If you do the search from your house it will get places closer to you.
If you cant find a decent 87 tank, I suspect you could use the newer tank and either
1. Take the pump out and replace it with a piece of tubing of the same dia. as the pickup.
2. Use the pump, bypass your mechanical pump and install a regulator with a return line.
If you do have to use a newer tank, get the electrical plug in case its different.
