Code 1-1 and hood latch stuck
Old Jun 23, 2019 | 08:07 PM
yermyjermy's Avatar
yermyjermy
Default Code 1-1 and hood latch stuck
truck stalled when taking a turn slow. started back up, no cel shown. Turned key on and off and got 1-1 code. Anyone have experience with this?
also, hood hinges broke off and the metal part that latches from the hood to the grill got bent. I bent it straight and closed the hood. Now it's stuck in there. any tips?
Old Jun 24, 2019 | 10:43 PM
onemore94dak's Avatar
onemore94dak
You sure that isn;t a code 11? Which is with no CEL No crank reference signal detected during engine cranking.
There are vids about the hood. I think you will need a very long flat head screw driver and a light and to come up from below and slide the screw driver up into release the first lock. I think I posted pics of mine for someone let me look.
Edit- Look at my pictures (IDK if other members can view them) the last one shows the hole on the body that the hood latches into. You'll have to come up from below and slip the flat screwdriver in and slide it along to the driver side and get it to release.
Old Jun 24, 2019 | 11:23 PM
yermyjermy's Avatar
yermyjermy
yes, it's a code 11.
Old Jun 26, 2019 | 08:55 AM
DodgeCares's Avatar
DodgeCares
Are you thinking of getting this inspected by your Dodge dealer? If you end up going in and need an additional layer of assistance, let us know.
Jasmine
Dodge Social Care Specialist
Old Jun 27, 2019 | 12:27 AM
Noonbailey501's Avatar
Noonbailey501
Jasmine
Sorry not to hash on any dodge dealership or anything, but very few things they can do yermyjermy that with a little time, research and back woods ingenuity that you can’t. The guy that I bought the truck from said he took the truck in and needed to get just a basic tune up (sparks,wires,fuel filter( all stuff most people can do themselves ))and told him that if the was anything else they’d take a look. he ended up with a bill around $1200 dollars. Came to find out they did a smog test and failed him and told him he couldn’t leave with the vehicle unless he got a bunch of other things put on like the catalytic converter,EGR etc just to pass .which in VA a smog test which even need unless you live in Washington DC area but I’d really don’t like when people or company’s say stuff like if you need additional assistance we’ll help let us know because they gonna nickel and dime you on everything they do. I hate to rant but like RP tells a lot of people do your research and buy a full version of a repair manual for the trucks year. I’m not the smartest person but I will say That after my purchase of the book I feel way more comfortable knowing that it’s getting done the same way as the tech but at a quarter of the cost and if next time it happens I can do it again and again (as long as parts are available).
Old Jun 27, 2019 | 02:49 AM
yermyjermy's Avatar
yermyjermy
I read if it was the CPS, it wouldn't crank. Well when it dies it doesn't start for a few tries then fires back up to get me home. Gonna swap it out and see what happens
Old Jun 27, 2019 | 09:29 AM
onemore94dak
The code description for 11 when there is no CEL is "No crank reference signal detected during engine cranking." that does not automatically mean the sensor is bad. It could be the plug at the harness is loose or something along the wires up to the computer is bad or the plug or pin connection on the computer has come loose. This will show how to tighten the pin connectors if that is the problem. http://www.merkurboys.com/wiki/index...xtraPinInstall
But if you have a good CPS on hand already and it fixes the problem ignore me
Old Jun 28, 2019 | 10:00 AM
DodgeCares's Avatar
DodgeCares
I understand where you're coming from, Noonbailey501. If you do end up going into the dealer and would like an added layer of help with that process, don't hesitate to send us a direct message.
Jasmine
Old Jun 29, 2019 | 12:51 AM
yermyjermy's Avatar
yermyjermy
is there a rubber grommet that goes around the crank position sensor? if so anyone know the part number?
Old Jun 29, 2019 | 10:58 AM
onemore94dak
Click on one of the pictures this is what they look like https://www.rockauto.com/en/catalog/...on+sensor,7196
I installed it as is and there was no grommet I am aware of involved.
