Intermittent--Intermittent wiper problem
Do you have intermittent wipers (deliberately intermittent), or just two speed wipers?
But basically, 12V is fed from the ignition switch; the intermittent wiper control module grounds the motor as does the park switch on the wiper motor when it's off park. Then when you turn it off, the park switch keeps the ground until the blades park, then the park switch opens turning the wiper motor OFF. There's also a high speed ground for the fast wipers.
You need to check 12V into the wiper motor when it's not working, and check for a connection to ground when the wiper is turned on.
RwP
RwP
RwP
RwP
I checked the 12 volts into the motor and it checks out fine.
When the weather is cold, the intermittent system works in all modes. In warm weather, intermittent may give one or two swipes and then nothing. I'm wondering if the contacts are expanding or contracting causing a hit-and -miss situation.
If it IS the control module, where is it located?
For most years (including a 1992!), it's behind the mono speaker grill; well, actually, it's attached to the driver's side tab of the metal grill.
Remove the kick panel, and it should be right there.
For a 1992, the module is a 4503104 in case you have to go hunting for one.
I find them used on Ebay easily enough.
But - if it quits when it's warm, but works when it's cold, I'd remove the housing and hit all the solder joints in case one's failed on you.
(Does the low and high speed work, or not?) If it helps any, in the factory service manual, it's about page 462, or 8W-79 for the paper copy.)
RwP
RwP
RwP
RwP
Thank you so much for your help!
Or if you prefer electronic copies, check http://www.autobooksbishko.com and pick up the CD with the PDF.
Or not; but it'll have the wiring diagrams and the test trees to locate problems quicker and easier.
RwP
Trending Topics
Go back on Ebay, and locate the Chrysler Factory Service Manual for your truck also. I see one that's under $20 delivered.
RwP
RwP
