New Member
New Member
I just recently got into dodges. We had a few 440 engine
s sitting around the shop growing up and a 1972 charger, but my first dodge is a 1992 Dakota extended cab 5.2L.
I drove a couple weeks with way too much transmission fluid and now it's done but the engine is good. May send it to the junk yard.
I have a Mopar High performance ECU and some headers I plan on transferring to another 1992 dakota, when I find one, just going to get rid of the current one.
I want to find a regular cab with a short bed. Will do a Naturally Aspirated build, ported throttle body, maybe the hughes custom intake manifold. The plenum gaskets are such a flaw.
If anyone takes this truck off my hands for the 318 they will probably want another intake manifold..
What way are you talking about?
Replace the gasket that is in there, with a GOOD quality Fel-Pro, or similar gasket, and use shorter plenum bolts. Or, cut the unthreaded nubs off the original bolts. Some blue lok-tite, and problem solved.
Those bolts only get torqued to like 72 inch pounds...... and you broke 'em??? Did you make the oh-too-familiar mistake of misreading that as Ft-lbs??
If I recall correctly I think they snapped at 23lbs and I thought they were suppose to be set arount 27lbs. I may have made a mistake, I did some research before hand and never read the 72 inch. I think when I find another truck I may just get a plate welded on there. Or get an aftermarket performance manifold. I really should have cut the bolts, i was in a bind with a dull hacksaw and gave up after the first one with some extras i had. I would have used an angle grinder but I was afraid of getting my hands that close on a short bolt.
Oh wow if it was 7lbs I definitely did something wrong. Unless I'm thinking of the intake manifold bolts that were about 27 or 28lbs. I think I was thinking of the manifold bolts, but the plenum bolts I'm sure I went well over 15lbs with. And yeah I probably did think the 24 inch lbs was foot lbs. I don't know alot, learning everyday.
I worked on the engine line at the Honda factory, everything is preset and I learned a little there but know less than most backyard mechanics.
Trending Topics
Ooops. Don't feel like the lone ranger there though. You aren't the first to make that particular mistake.
I'm in Alabama. The transmission is bad, I kept adding fluid, like 6 quarts too many and drove it about a month, I was going to drain the excess fluid like 2 days before it finally quit, the transmission started making all sorts of noises and started slupping until it just quit.
I just ordered an ebay transmission with a 6 month warranty. Will pull the bad one and have it rebuilt eventually.
The truck has a dented bed, I'm going to paint it with a foam roller once I get a good bed on it.
