Options as to how I can replace my rear speakers in my 95 dakota SLT
So I bought a pair of 6x8 (or 5x7 if you will) after replacing my 2 front speakers. Anyways, I'm not sure how to remove the rear left and right side panels to get to the speakers. Im able to remove the seatbelt bolts and the trim screws, but she wont get more free than a wiggle. Someone please tell me what I have to do to finish removing the panel, thank you.
Regular cab or extended cab?
(The method is the same - remove everything holding it - but the specifics vary a bit.)
Edit: Brain storm struck after hitting "POST". If you'll go to the stickies at the top of the subforum, the third message says it's a FAQ (fourth is FAQ2). About 40% of the way down on the 3rd message is a link to the factory service manual for the 1995 Dakota. (Also the 1996, different link, same location). Download that and it should have the instructions in the interior trim portion. Also, there's the 1993-1996 Parts List in that same area; the exploded parts diagram for your truck may help see what's holding it still.
RwP
RwP
