Upper Ball joint issues
Old Dec 9, 2019 | 06:54 PM
Shane Corners's Avatar
Shane Corners
Default Upper Ball joint issues
I am posting because I want to know if anyone else has the same issues. I have taken my 93 4X4 to A local chain shop for an alignment and ball joint replacement. Initially my passenger side upper was supposedly bad cause the threads were bad. The shop couldn't find A new one so I was able to get A used one from A local salvage yard. I installed the salvage control arm with it's own upper ball joint that was ok. I should have left it at that, but I paid for 4 new ball joints and they had agreed to warranty said ball joint and alignment. They did so and I drove home and I heard A light pop crossing railroad tracks. I knew it was not good. I fully expect the shop to make this right, did they try to air chisel out A threaded ball joint? I have contemplated going with A solid front axle on it for some time, has anyone done that on here, look forward to any responses, thanks.
Old Dec 10, 2019 | 06:37 AM
93 ragtop's Avatar
93 ragtop
If it was mine, assuming the ball joint is not hurt, I would screw it back in, and then put 3 small welds on the surface where the ball joint touches the arm.
